Issue on the front wheel area!
Old Mar 28, 2011 | 01:08 AM
maxime75us's Avatar
Default Issue on the front wheel area!
Hi All,
It appears a few months ago, when I get in or out of the driveway, I could feel a little lose .. something on the left wheel area.
Now, once in a while, I can hear a "clang" noise and a crack"" noise.
I believe a few times I was making a U-turn and I could hear the noise but mostly it happens when I get on the driveway or bump...
Would you tell me which parts might be affected?
Thanks one more time for your help,
Max
Old Mar 28, 2011 | 06:25 AM
magredvet's Avatar
Default Re: Issue on the front wheel area!
Try the steering damper, common problem at about 30K give or take. I have a similar noise, and my damper is shot (leaking) About $45 from amazon, and two bolts to change it ............
I'll let you know if the noise disappears after i do mine ...............
Old Mar 28, 2011 | 07:38 AM
dtinker's Avatar
Magredvet:
Where are you on your repairs? did you get pump and separator installed, fuel pump, etc? Big task!
Old Mar 28, 2011 | 02:58 PM
magredvet's Avatar
The pump, regulator, solenoids, zeitronix, etc are all installed and wired up, just waiting on the y pipe for the boost connection, then we can head to the dyno !. It starts and runs , and now I have datalogging capabilities ............
Spent all day Saturday, but now it's done. Just need to find the time to fit the steering damper, and do the valve cover seals .............
Old Mar 28, 2011 | 03:18 PM
dtinker's Avatar
Let me know when you get set up with Jerry. Let him know that I will be coming and bring my car too. I will be traveling Wednesday, but if you need some help I could come over on Thursday, Friday, or Sat. Let me know.
Old Mar 28, 2011 | 03:23 PM
magredvet's Avatar
Ok Dave thanks. It all depends when the y pipe arrives, as I may have a break this weekend if I don't get it by Friday. It will be a break from the car only, as if I'm not working on it I'll be tiling the porch, or some such ..................no rest for the wicked !!!..................
Old Mar 28, 2011 | 05:28 PM
dtinker's Avatar
Glad to help anytime.
Old Apr 29, 2011 | 05:01 PM
maxime75us's Avatar
To Magretvet.
did you fix the issue with your damper?
let me know,
Thanks,
Max
maxcichon
May 14, 2019 07:30 PM
Roty135
17
Oct 11, 2018 10:11 AM
tom2112
Jul 28, 2015 08:12 AM
axnguyen
Jul 21, 2015 11:41 AM
UNDER PSI
Jul 18, 2015 02:12 PM
