Oil Change Info
Old Apr 4, 2011 | 10:20 AM
fener88's Avatar
Default Oil Change Info
So I am looking to get an oil change for a NA crossfire and was contemplating if taking it to MB would be my best option. I do not want to bring it to the local Chrysler dealer as I haven't had a good experience with them when my car was having problems with random shutoff (RCM - thank god for this forum) and one of the mechanics pretty much acknowledged that a bunch of idiots works there. This is gonna be the first oil change under my ownership so I don't know if the car even needs one but id rather be safe. Also, what has become the norm on the forums when it comes to the frequency of oil changes.
PS. I am in north NJ if anyone has recommendations...
Old Apr 4, 2011 | 10:45 AM
maxcichon's Avatar
Default Re: Oil Change Info
Many here do the work themselves.
One way to do it is to buy the 9 qts of Mobil 1 0W40 oil and a filter and carry it in to a trusted shop. Or even a Quicky Oil Change place if they'll do it with you watching. Labor costs only.
Old Apr 4, 2011 | 10:59 AM
32krazy!'s Avatar
mobil 1 on sale as we speak at oreilly's for 4.99 a qt. call the m/b dealer first. most wont work on a xfire.
Old Apr 4, 2011 | 11:13 AM
As Steve said, most of the MB dealers don't want one of our red headed step children being seen on one of their lifts. They must think it will give legitimacy to the fact that the car is damn near a mercedes, and that is something they don't want the public to know LOL
Go to a trusted Euro repair shop and take your oil and fleece filter, that is the only way to ensure our not very common oil finds its way into your car...
Old Apr 4, 2011 | 11:16 AM
fener88's Avatar
yeah i just got rejected by three mb dealers... i was reading something about o-rings before, do i need them in addition to the filter n oil
no oreillys in nj
Old Apr 4, 2011 | 11:35 AM
maxcichon's Avatar
The orings are supplied with the new filters. Make sure, as said, to buy a "fleece" filter as opposed to a paper filter.
Mann, K&N, and Purolator make fleece. make sure with the Purolator, as they also make a paper.
K&N P/N HP-7004
Mobil 1 P/N M1C-253
Mann P/N 718/5
Old Apr 4, 2011 | 11:39 AM
32krazy!'s Avatar
no oreillys in nj
most advance or autozone will honor competitors coupon. try that
Old Apr 4, 2011 | 11:40 AM
Rob M's Avatar
no oreillys in nj
The filter element comes with a small bag containing new O-rings. They are used to replace those on the center shaft of the filter housing on which the filter element is installed. Another thing you need to consider doing is replacing the oil plug washer (original equipment is a copper crush washer that can result in oil drips if not replaced each oil change). You only need 8 quarts Mobil 1 OW-40 (or other oil that meets specs). Even though the specified capacity is 8.5 quarts, you can never drain all the oil out during an oil change. Your Crossfire should require exactly 8qts be added.
Old Apr 4, 2011 | 11:53 AM
fener88's Avatar
alrite im gonna just get the following filter and just pick up the oil from autozone. how often do you guys go between oil changes
Amazon.com: K&N HP-7004 Oil Filter: Automotive
Old Apr 4, 2011 | 12:51 PM
Crossfire725's Avatar
i live in north jersey as well. i do it my self
Old Apr 4, 2011 | 01:06 PM
maxcichon's Avatar
I wait until the Service Indicator (FSP?) tells me to. ~ 7000 Miles.
I'm not too sure about Rob's engine, but mine has always taken 8.5 qts.
Old Apr 4, 2011 | 02:17 PM
Rob M's Avatar
8.0 qts is generally the more accurate amount of oil to add when changing. The reason for 8 qts instead of 8.5 (total capacity) is because not all the oil will drain or be pumped out during a typical oil change. One or more forum members have actually reported "HI" oil level computer readings after adding 8.5 qts. 8 qts added should result in a manual dipstick reading somewhere in the upper half of the acceptable range. Plus, you save approximately $3 each time you change your oil.
Rob M's Avatar
sorry... inadvertent double post.
Old Apr 5, 2011 | 04:19 PM
fener88's Avatar
so how necessary is the oil plug washer and where can i pick it up
Old Apr 5, 2011 | 04:27 PM
32krazy!'s Avatar
its a 1 time use washer. called a crush washer. it will leak a drip or two after being reused. needswings has the pack you can buy or most auto parts houses can get you what you need
Old Apr 5, 2011 | 04:35 PM
TomStratRT's Avatar
Or, buy an extractor and never worry about crawling under the car to drain oil again.
xfClifford
Mar 3, 2021 04:52 PM
PNA
Nov 12, 2020 04:44 PM
sittininthesun
Aug 24, 2015 10:47 AM
xfClifford
Aug 3, 2015 11:03 PM
skeet370
Jul 18, 2015 01:02 PM
