What's that? What's what? Its a squeaking sound...
Old Apr 4, 2011 | 07:44 PM
MAYAman's Avatar
Default What's that? What's what? Its a squeaking sound...
"You couldn't hear a dump truck driving through a nitro glycerin plant" LOL
But seriously, when I turn my wheel, I hear a squeak. When I turn in the other direction the squeak gets louder. And I mean LOUDER. Its really annoying. I hit a pot hole about three weeks ago but didn't hear any squeak till yesterday.
So.....back and forth on the steering wheel and I get squeaks coming from deep inside the dashboard. Please help.
Hope you enjoyed the Christmas vacation reference.
Old Apr 4, 2011 | 07:49 PM
green-ghost's Avatar
Default Re: What's that? Whats what? Its a squeeking sound..........
your steering wheel fluid needs changing
Old Apr 4, 2011 | 07:52 PM
MAYAman's Avatar
Thats it? Whew, I hope you're right. If thats it I'll be damn happy. Can anybody confirm?
Old Apr 4, 2011 | 08:56 PM
LantanaTX's Avatar
It might be a front wheel bearing.
Old Apr 4, 2011 | 09:24 PM
MAYAman's Avatar
Hmmmm that would suck, even though it sounds like it is right behind the instrument cluster. Weird. I'm dreading going to the dealer. Ugh.
Old Apr 4, 2011 | 09:25 PM
MAYAman's Avatar
By the way I'm going to assume that's dangerous?
Old Apr 4, 2011 | 10:20 PM
MikeR's Avatar
Probably not eminent, but eventually...yes...
Old Apr 5, 2011 | 07:08 AM
HellsAngel91's Avatar
Default Re: What's that? Whats what? Its a squeaking sound...
it's probably your wheel bearing! you need to get it sorted out now, i waited to long (about a week or so from the time i first heard it). It also it also messed up my spindle and hub....luckily i convinced the company i have my extended waranty through to fix everything. so go get it checked out! hope you get it sorted out.
Old Apr 5, 2011 | 12:04 PM
JHM2K's Avatar
Are the spindle and hub like everything else on this car? In other words, order Mercedes and it's cheaper?
Old Apr 5, 2011 | 12:26 PM
AlG's Avatar
AlG
My advice....only drive straight, this way no squeaking. But, have you checked the serpentine belt. Could be worn and squeaking on the pulleys when the wheel is turned. Open the hood, have someone turn the wheel and try to get a better idea of where the sound is coming from.
Old Apr 5, 2011 | 02:14 PM
Goldwing's Avatar
There are a lot of rubber bushings in the suspension and steering. I liberally spray (the femine hygiene spray reference was ******) mine annually with a good silicone spray and it seems to reduce the squeaking. Does it make noise whether moving or parked?
Old Apr 5, 2011 | 03:37 PM
rekcah's Avatar
check steering damper
https://www.crossfireforum.org/forum...surprised.html
Old Apr 6, 2011 | 10:07 AM
MAYAman's Avatar
Default Re: What's that? What's what? Its a squeaking sound...
^^^Would that make a squeeking sound? I thought that was a clunk. this sounds like two pieces of plastic rubbing. Something like that.
Old Apr 6, 2011 | 12:28 PM
MAYAman's Avatar
OK update.
During lunch I went into the parking garage where its nice and quiet. I started the car and made sure the wheels were straight and I was on a level surface.
Soooo, when I turn the wheel either right or left there is literally a 2 to 3 inch dead zone. Then a slight what seems like a "thunk". In the dead zone the squeek is subtle. After the "slight thunk" the squeak becomes louders. Definitely sounds like its coming from inside the dash but that could be deceiving.
Please help. LOL
Old Apr 6, 2011 | 09:07 PM
rekcah's Avatar
Not sure what sound the steering damper makes but another member describes it as a grinding noise.
Originally Posted by 04Fire
I've put almost 7k on the new damper... from JoelTLC... and it's already shot and now makes a horrible grinding noise every time I turn the wheel at low speeds. So needless to say it needs to be replaced... so does anyone recommend or know of a different brand with a little longer life span? I know it's only $30 but gees.
The steering damper is on the very bottom of the car about a foot in front of the instrument cluster. Very easy to check.
Old Apr 7, 2011 | 09:54 PM
MAYAman's Avatar
Definitely not a grinding noise, it sounds like plastic on plastic.
brian_omeara07
Jan 2, 2009 06:48 AM
tylerxfire
May 5, 2008 07:46 PM
xfireblur
Feb 27, 2008 10:21 AM
convertiblenut
Jan 11, 2006 04:17 PM
kraz17
Apr 22, 2004 04:34 PM
