Is she dying? Definitely does not sound good. (Video Inside)
Originally Posted by SilverWolf
Remove the belt and fire it up! If the noise goes away, It's not your motor. Takes all of five minutes to do and calm your fears about the motor being shot.
Oh. Forgot the beer break!
Status?
Ok, I will remove the belt, fire her up, and report back. Thanks fellas. I hope this isn't serious, this car is never being abused. It is a daily driven, babied car. I will first check the alternator, and then the water pump.
I tend to agree. Alterntor or a pulley rubbing something.
I get the same sound if my CIA comes loose and touches the Serpentine belt.
The fact that he has no loss of drivability suggests something simple. Outside the engine.
roadster with a stick
Had the same thing on my roadster few weeks back. At idle car sounded terrible at speed no noise at all. New water pump did the trick.
STATUS???
well, battery light came on yesterday, and i went ahead and bought an alternator. I am getting ready to do the swap.
Muscle, I am hoping you tested the pulley's and found the alt as the problem... anything that makes the belt loose/slip could cause the alt not to be spinning at correct speed... Just sayin....
Hope that you get that terrible noise resolved and back on the road....
**UPDATE**
I just got done installing the Alternator, and as soon as i cranked the motor, the battery light went away, the weird sound is gone, but now BAS ESP light is on.
Any thoughts?
I think it was the alternator, I honestly gambled, and bought the alternator for 200 bucks.
That weird sound would sometimes go away with the alternator, so, since it has been idling quiet and nice, I am hoping that I have fixed the issue. (fingers crossed).
Chances are your BAS/ESP light is just on because you cut power - it'll do that sometimes.
Turn your wheel all the way to the left lock and then all the way to the right lock and the BAS/ESP should reset.
jhansen
21
Feb 15, 2017 04:26 PM
unarel32
35
Oct 6, 2015 05:53 AM
