Windshield washer fluid
Old Aug 4, 2011 | 04:13 AM
VIPER0076's Avatar
Default Windshield washer fluid
Is there a way to know when the fluid resivour is full before it startes running out on the floor when you fill it up ?
Old Aug 4, 2011 | 04:35 AM
robby363's Avatar
Default Re: Winshield washer fluid
When the light comes on it will hold 1 gallon without leaking.
Old Aug 5, 2011 | 03:11 AM
MRGR3YXF's Avatar
Went and got oil change and they attempted to fill my windshield washer fluid up and discovered i have a hairline crack in it?? Which results in leakage into oil pan?
little problems vs awesome car
Old Aug 5, 2011 | 05:20 AM
robby363's Avatar
Probably nothing wrong with the tank. You can't tell when the tank is full until you see it leaking onto the ground and then most people think it's cracked. It says in the manual it will hold 1 full gallon after the low level light comes on and any more than that will leak.
Old Aug 5, 2011 | 05:23 AM
green-ghost's Avatar
keep mine just above empty to save weight. Really never had the windshield get so dirty that I had to ever use them
Old Aug 5, 2011 | 07:45 AM
VIPER0076's Avatar
I guess i should have "RTFB" (read the f#*&* book). I never waited for the light to come on, I would just add to it whenever I thought it might need it.
Old Aug 5, 2011 | 09:58 AM
Kodebuster's Avatar
If in fact the Tank has a hairline line crack, and it was not subject to an over fill, here's an easy fix, rather than replacement.
Just get a Hot Glue Gun and run a bead of hot glue along the crack, and let it dry, cold to the touch.
In my Daughters Pontiac, I had a hole develop in her Radiator over flow Tank, due to vibration and wear against the mounting, along one corner.
I hit the hole with Hot Glue, re-installed the Tank, and it's been holding hot radiator fluid ever since.
I'm sure hot glue will work with a cold fluid Tank, no-problem-o...
syfi
Mar 28, 2026 04:14 PM
UNDER PSI
Nov 1, 2015 09:39 PM
jimf
Oct 10, 2015 10:22 AM
Sep 26, 2015 10:21 PM
Jackobo
Sep 24, 2015 10:21 PM
