Brake Light Replacement
Old Nov 7, 2011 | 07:10 AM
themush1326's Avatar
Default Brake Light Replacement
Is there a trick to replacing the brake light on a 2005 Coupe?
I accessed the bulb with no problem but when I replace the light it doesnt feel secure.
When I press it doesnt samp or anything to indicate its locked.
When I press it gives and bit but then pushes back
Do you just simply press in place?
Also the warning light went from ON to OFF then ON when pressing the brake pedal, now its back on all the time.
Old Nov 8, 2011 | 06:15 PM
Vegaslegal's Avatar
Default Re: Brake Light Replacement
The light turns in the socket to lock it in. Push it all the way in where the two slots for the two nubs are, and turn. The socket turns into the lamp housing pretty much the same way, but they are not nubs, they are tabs. Once turned its very secure and solid. If you don't have that feel, you haven't done it right.
Old Nov 8, 2011 | 09:10 PM
texas t's Avatar
Red face Re: Brake Light Replacement
I"m having to replace my bulb socket on the brake light, for some reason it melted slightly and the blub, will not turn in socket . Can get the light to come on but comes loose and goes out.
Roty135
17
Oct 11, 2018 10:11 AM
jgreen
106
Sep 18, 2017 11:46 PM
KwehCat
Jul 16, 2015 04:48 PM
westonrose
Jul 14, 2015 11:25 PM
Blackout317
Jul 7, 2015 08:38 PM
