key wont turn
You need to read this new guy
https://www.crossfireforum.org/forum...n-key-fix.html
WELCOME to the forum!
Lots of good info here:
https://www.crossfireforum.org/forum...tml#post504963
Easy... depends on your comfort level and mechanical ability in working on your own car. Have a quick read above and you should be able answer this yourself.
Hope this helps
Hope this helps
Sometimes when the wheel is turned some the key won't turn. Pull on the wheel with one hand and try to turn the key with the other. The cause in this case is a little pressure on the locking pin when the wheel is turned.
88stevie
19
Jan 21, 2026 01:46 PM
SparkieSRT6
Jan 11, 2016 10:49 PM
unarel32
35
Oct 6, 2015 05:53 AM
