Notchy 1st to 2nd Gear Change ???
Old Jan 3, 2013 | 11:27 AM
sk8erjosh09's Avatar
Default Re: Notchy 1st to 2nd Gear Change ???
From the Manual :
Manual Transmission
Selection of Lubricant
No fluid service is required. Use only fluid approved to
MB 236.2. SAE 5W-20 engine oil, meeting API SL or GF-3,
may be substituted. Refer to the Recommended Fluids,
Lubricants
Old Jan 3, 2013 | 02:53 PM
NO, boiler is talking about changing the TRANSMISSION "fluid".
While I was referring to putting it in the transmission, it is engine oil indeed
You are good with any approved or high end 5w20 that conforms to the standards Josh posted.
Boiler's advice is spot-on, but on the other hand, I test drove a Base Roadster with 120,000 miles on it and it shifted smooth, even going from 1 to 2.
Probably worn enough to be 'smooth' I personally prefer the tightness mine has...
Old Jan 3, 2013 | 04:00 PM
Chris L.'s Avatar
At about 87,000 original owner miles my 6 speed is running better than ever......I typically take it up to 2500 to 3500 RPMs on that 1-2 shift &........nothing but SWEET!
Old Jan 3, 2013 | 04:34 PM
I know, I bought Mobil 1 5W20 for mine.
I thought what I was quoting made my meaning clear - but I guess not!
Old Jan 4, 2013 | 04:42 PM
Nordschleife's Avatar
We've had this discussion over and over in the SRT4 world. We even had a Chrysler engineer that had a hand in designing the 5 speed tranny for the NSRT chime in and he told us that as long as it was a high-ZDDP oil that it would be fine. Mobil1 syn oils that met the criteria were only the "high mileage" oils, specifically 10-40. The only other consideration is the coefficient of friction (the NSRT required friction modifier) so if guys are running their MANUAL transmissions already with syn without grinding then I would say that it is fine. It will not ruin any internals.
That said, the word manual is capitalized because this does not apply to the auto trans for the Crossfire. (my CYA statement heh).
deerhunter
Jan 16, 2021 10:56 AM
JEFASOLD
Nov 14, 2015 10:39 PM
Rets
Aug 23, 2015 06:31 PM
xzmilan
Jul 22, 2015 10:40 AM
XFIRED-TX
Jul 14, 2015 10:48 PM
