gear knob replacement
Old Jun 4, 2012 | 01:41 PM
GrantB's Avatar
Default gear **** replacement
Before i attempt to twist the gear **** of my manual transmission XF....
Does any one know how its held on before i bust it accidentally ???
Is it screwed on or locked with Allen Screws or what ????
Would rather not destroy the selector forks finding out ha ha ......
Grant B
Old Jun 4, 2012 | 01:51 PM
Default Re: gear **** replacement
Grant B
I have not done it but I think the bottom part of the **** unscrews first.
Old Jun 4, 2012 | 02:32 PM
Tjb421's Avatar
pull up the leather boot first, and get it out of the way, and I THINK that there is something there that you can unscrew that keeps the **** tight on the shaft. It's been a while so i don't remember, but i DO know if you yank hard enough on it, the **** will come off. but you'll probably destroy the **** attachment (Depending on how tightly it's screwed on right now). And depending on what you're doing, (replacement?) you may not need the **** to reattach. On the bright side, it shouldn't hurt the shaft it's attached to. I am pretty sure there is something to unscrew though, pull up the boot and check it out.
Old Jun 4, 2012 | 02:50 PM
Mrmiata's Avatar
When I replaced mine.. I didn't note a difference between manual and automatic removal in the forum.. 180 is correct.. the bottom section unscrews from the upper section. And that puppy can be on tight..lol. Seems like I had wrapped mine with duct tape to be able to get enough grip on it.
Old Jun 4, 2012 | 05:39 PM
GrantB's Avatar
Default
Many thanks gents.
Will attack it in the morning and fit the new ****.
Regards
Grant B
Old Jun 5, 2012 | 12:26 AM
rayth's Avatar
I had the opposite experience... specifically I've pulled the entire boot and **** off when trying to go into Reverse... guess I don't know my own strength
Old Jun 6, 2012 | 09:50 AM
GrantB's Avatar
Hell, I won't get into a tussle with you.... or shake your hand....... might loose my arm ha ha
Buchacho
Aug 6, 2015 12:48 AM
needfreetime
Aug 1, 2015 07:06 PM
maxcichon
Jul 31, 2015 11:34 AM
XFIRED-TX
Jul 17, 2015 11:56 AM
XFIRED-TX
Jul 14, 2015 10:48 PM
