Starting issue
Old Aug 1, 2012 | 06:19 PM
Jeff Ark's Avatar
Default Starting issue
Every now and then it seems like my engine cranks in excess before starting. It doesn't do it all the time , but i think it's becoming more often. Has anyone experianced this also.II have a 2005 with 35,000 miles and rreally have had no problems with it. Thanks
Old Aug 1, 2012 | 06:28 PM
Default Re: Starting issue
Original battery?
Original Crankshaft Position Sensor?
Running panther **** instead of 93 octane gasoline?
Old Aug 1, 2012 | 06:34 PM
Jeff Ark's Avatar
New battery! Always use premium fuel.Is replacing the Crankshaft Position Sensor a big job? I appreciate your help!
Old Aug 1, 2012 | 06:35 PM
As Mark just mentioned, this is usually the early signs of a Crankshaft Position Sensor failing... Sometimes starts hard, and idles rough. Shut it off, restart and it is fine....kind of thing.... but others will tell you a lot more than me....what do I know....
Old Aug 1, 2012 | 06:36 PM
Search "CPS" - you will have it replaced yourself in 20 minutes or less.
Get one at Autohaus in Arizona, about $55 shipped - you want a BOSCH part, not a generic one.
My car has 77,000 on it, never had it fail. But that is PROBABLY 'cause I carry a new spare one in the trunk (because it seems EVERYONE here but me has had a failure).
Old Aug 1, 2012 | 06:37 PM
Jeff Ark's Avatar
It runs fine after it starts, but once in a while it seems to crank longer than normal when you start it. Thanks for your input.
Old Aug 1, 2012 | 06:42 PM
The other thing the CPS does is cause the car to not run when it's hot.
It's a known failure item and easy/cheap to change. I'd try it and see what happens.
Keep us posted, so we can pass on the knowledge to others!
Old Aug 1, 2012 | 06:54 PM
Infinity's Avatar
Have you replaced the fuel filter yet...35k it's time...remember the pressure regulator is part of the filter on our cars
Old Aug 1, 2012 | 07:03 PM
Jeff Ark's Avatar
Never thought of the fuel filter.Is that much of a project? Thanks everyone for the great words of wisdom!!!
Old Aug 1, 2012 | 08:25 PM
dhenz's Avatar
would it help if he'll replace the battery?
Old Aug 1, 2012 | 09:31 PM
He said it's a new battery.
Fuel is probably leaking down in pressure and the fuel pump has to make it up as mentioned above.
Old Aug 2, 2012 | 07:54 AM
Infinity's Avatar
Default
It's easy to do, drop plastic cover at the rear of the car, clamp fuel lines, remove clamps, and swap filters
KDW4Him
18
Sep 1, 2021 05:47 PM
PNA
Nov 12, 2020 04:44 PM
northwest_crossfire
May 30, 2016 05:19 PM
Bayukbros
Jul 17, 2015 11:21 AM
FIXRE
Jul 9, 2015 09:16 PM
