Air Pump problems...Help!
Old Aug 24, 2012 | 11:55 AM
aphuntin's Avatar
Default Air Pump problems...Help!
I attached a pic last night I had smoke coming from this part and it made a loud whining noise....is this my air pump?>
Old Aug 24, 2012 | 12:51 PM
MrMoPar's Avatar
Default Re: Air Pump problems...Help!
Yes, yes it is.
Old Mar 8, 2013 | 03:35 PM
Spenzer4Hire's Avatar
This afternoon I parked my car and went into a store for about 10 minutes. When I got back i heard the whirring sound of a shop vac coming from under my hood. I drove a couple of miles back to work and it was still running even when the engine was turned off. I located the part (air pump) but didn't know what it was. I quickly ran out to a local repair shop where they pulled the plug on it. It was crazy hot and smelled a little like burning, but it still appears to function. No CEL or anything abnormal.
After we plugged it back in and I started the car it's been functioning properly (i.e. shutting off when the car is off). Thoughts? If it's a failing relay, should I have it proactively replaced? I'm currently unplugging the air pump when I'm not driving, just in case it decides to start up and I'm not around to hear it.
Old Mar 8, 2013 | 03:42 PM
Have a look at the relay for the air pump inside the RCM, if the contacts are burnt you could clean them up.Replacement of that relay would be a good idea if that is the problem.
I am assuming that you switched off the engine when you went into the shop.
There is a thread that shows the burnt contacts.
Old Mar 8, 2013 | 03:58 PM
Yes, I shut off the engine at the repair shop to show them the issue. It's only been unplugged while the engine is off.
I think I found the thread you're talking about: https://www.crossfireforum.org/forum...conundrum.html
Thanks onehundred80, I'll play with it this weekend.
tritongreen
Sep 18, 2015 07:32 AM
RacerXofFL
Sep 15, 2015 05:00 PM
cppeabody
Sep 15, 2015 08:43 AM
81's
Sep 13, 2015 04:34 PM
crmnal
Sep 6, 2015 08:07 AM
