noticed some popping noise
Old Oct 6, 2012 | 07:36 PM
RandyDaMan's Avatar
Default noticed some popping noise
Recently I have noticed some slight popping noises from my XF when I go over bumps at slow speeds. Has anyone else experienced this and could it be rubber bushings on the suspension?
Old Oct 6, 2012 | 07:50 PM
Default Re: noticed some popping noise
You baby your car too much, take the bubble wrap of it when you take the car out.
Old Oct 6, 2012 | 08:14 PM
RandyDaMan's Avatar
Thanks for the less than constructive advise...fortunately most people on this forum are more helpful!
Old Oct 6, 2012 | 08:38 PM
Mrmiata's Avatar
I've read a few occasions of the sway bar mount being broke and producing "popping" noises.. think it cracks loose at the frame..
Old Oct 6, 2012 | 11:47 PM
Warren Smith's Avatar
A popping noise is a pretty general explanation of the problem. Can you be more specific? This could be many things. On a turn, straight driving, front or rear noise etc.. That would probably be of more help in the diagnosis. A check of the sway bar bushings as suggested would also be a good idea.
Old Oct 7, 2012 | 09:34 AM
My point exactly, a popping noise, what is that exactly?
Old Oct 7, 2012 | 10:57 AM
RandyDaMan's Avatar
Perhaps I was not descriptive enough with my question The noise seems to be coming from the underside rear of the car. It may be best described as being a combination of a pop, and a creek. Have heard it both while traveling straight and turning at low speed 20 MPH or less. It may be happening at higher speeds but other road noise may be masking it.
Old Oct 7, 2012 | 11:00 AM
user 72983's Avatar
Banned
^^^^^^^ Check/lube the sway bar bushings ....
( squirt 'em with some wd40 - if that helps, think about replacing them )
Old Oct 7, 2012 | 11:13 AM
Now we are talking about a whole new ball game here. We know it is in the location of the rear of the car. A suggestion would be to check the torque on the rear control arms. JMO
Old Oct 7, 2012 | 12:07 PM
Mrmiata's Avatar
Originally Posted by Rockbasses
You mean what am I talking about??
https://www.crossfireforum.org/forum...need-help.html
Old Oct 7, 2012 | 12:28 PM
user 72983's Avatar
Banned
No, no. I was agreeing with your post, sayin look above to your post and asking(?) if he understood what you just posted!
I tried to find the link you just posted...I was spelling Rebcah's name wrong. I knew I had just read that thread this weekend!
It's all good.
DJ
Old Oct 7, 2012 | 12:51 PM
Mrmiata's Avatar
Thought you had been around enough to know what I was talking about.. LOL. Now OP gets pics anyways..
Old Oct 7, 2012 | 12:56 PM
user 72983's Avatar
Banned
Yup.
I don't mess with anybody here! I'm here to read and learn!
DJ
Old Oct 7, 2012 | 12:59 PM
Mrmiata's Avatar
Yup.
DJ
Read, learn, sometimes share what you have learned.. My primary reason for being here. Doesn't always quite work out that way though.
Need a link for cheap ebay OEM filters?
Old Oct 7, 2012 | 03:18 PM
user 72983's Avatar
Banned
I got it from you! I'm frugal too!
blackpepper
Oct 4, 2017 06:09 AM
2005 Ragtop
Oct 3, 2015 03:01 PM
4drturbo
Oct 2, 2015 12:58 PM
Oct 1, 2015 01:42 AM
Charlesl
Sep 30, 2015 10:46 PM
