Resetting the fss
Old Oct 9, 2012 | 08:07 PM
Mongoose57's Avatar
Default Resetting the fss
Hi guys, I have tried to reset the fss on my 06 coupe three times .It is on schedule B and showing -750 miles ,I have compleated all the nessarry maintenance items and would like to get rid of that annoying reminder .
Any tips .I have followed the owners manual?
Thanks
Mongoose57
Old Oct 9, 2012 | 08:38 PM
Mrmiata's Avatar
Default Re: Resetting the fss
I don't know for sure that it made the difference.. but another member was having issues getting his to reset. I had suggested disconnecting the battery for 15 minutes and trying again. He reported back FSS reset worked first time after that. Mileage may vary should you try this.. LOL.
Old Oct 9, 2012 | 08:57 PM
Mongoose57's Avatar
Thanks , sounds like a reboot could work I'll give it a go and let you know the results
Cheers
Mongoose57
Old Oct 9, 2012 | 09:11 PM
Read the owner's manual more carefully.
You can only reset the FSS on the third full moon of every odd year ........
Old Oct 9, 2012 | 09:23 PM
Mrmiata's Avatar
And here you would have to wait two more years.. you forgot (autodim mirrors anyways) about "while looking over left shoulder"... fine print at the bottom..
Old Oct 9, 2012 | 10:19 PM
Afterguard's Avatar
Thanks
Mongoose57
The manual has some timing statements in it that are imisleading. If you wait the 10 seconds the book says to wait for the FSS to beep it never will. Just do the whole procedure lickity-split and it'll reset (most of the time). I think the trick is to do the entire procedure within 10 seconds max.
Old Oct 9, 2012 | 10:41 PM
JHM2K's Avatar
I could be mistaken, but I think you also have to have the door closed before the FSS reset will register.
Old Oct 10, 2012 | 04:28 PM
I was reading your stats John...and for the life of me...picturing you standing for a half mile at 135mph made me chuckle...lol... And, I even knew what you meant...rough day I guess...
Old Oct 10, 2012 | 05:27 PM
JHM2K's Avatar
I just point that big barrel-chest into the wind, and away we go
Old Oct 10, 2012 | 05:32 PM
LOL....I needed that...now back to the RESET....I never get it the first time while trying to reset it...I have taken up to 6 tries before....never have I had it work the first time....
Old Oct 10, 2012 | 09:05 PM
Thanks
Mongoose57
RESETTING THE FSS MAINTENANCE INDICATOR
1) Move the ignition switch to the “RUN” position
2) Within 4 seconds of moving the ignition switch into the
“RUN” position, press the reset button for the trip odometer
twice within one second.
The display for the FSS service request is activated for 10 seconds
3) During the 10 seconds the FSS service request is displayed,
move the ignition switch to the “OFF” position.
The FSS service request will continue to be displayed
4) Press the reset button for the trip odometer and hold
5) Move the ignition switch to the “RUN” position
6) Continue to press and hold the reset button for the trip
odometer (about 10 seconds) until the audible signal sounds and the new start distance appears in the display
The tool symbol should disappear at this time
Old Oct 10, 2012 | 09:11 PM
Mongoose57's Avatar
So here is what I prepose to do , when the moon is in the seventh house and car aligned with mars l will cycle the doors open/closed all the while resetting 6 times under 10 sec and NOT wait for the elusive beep. That should cover it.
Seriously though I will try everything
Cheers
Mongoose57
Old Oct 11, 2012 | 09:32 AM
Ed Mahoney's Avatar
Mine reset once on the 1st try !! Last time took about 4 trys !!! Yes you have to do it FAST otherwise it will not work !!!!!
Old Oct 11, 2012 | 11:20 PM
magneticred's Avatar
When doing the reset procedure, you have to turn the key all the way to the On/Run position. If you stop at the ACC position, it will not work.
Old Oct 17, 2012 | 09:31 PM
kurtisberry's Avatar
Before you try the procedure, do this! Push in the button and rotate back and forth about 20 times while holding in. This will take all the oxidation off the switch. Your trip odometer and fss will reset instantly after doing this.
Old Oct 17, 2012 | 10:26 PM
vinnys's Avatar
Push it in and rotate it back and forth about 20 times while holding it in???? Nine months later a doctor told me it was a boy!! Be very careful doing this reset!!!!
RedRover
May 26, 2021 02:09 PM
SparkieSRT6
Jan 11, 2016 10:49 PM
stelrz1
Sep 21, 2015 11:18 AM
tritongreen
Sep 18, 2015 07:32 AM
spoiler
Sep 2, 2015 08:56 PM
