Starting issues and key fob?
Old Jan 15, 2013 | 12:51 PM
Raptor's Avatar
Unhappy Starting issues and key fob?
Key fob would not unlock the car this morning, so I had to do it manually. Once inside the car I started it right up and it died. Started again, no problem, and it died. Now it will not start at all. All electronics work (lights, radio, buzzers, etc.). Even had my wife bring me the other key fob to no avail. I have no choice now, but to get it towed. Help!
Old Jan 15, 2013 | 01:30 PM
STEPHENJXN's Avatar
Default Re: Starting issues and key fob?
Crankshaft Position Sensor
Search within this forum for the above phrase. There are several post that describe the behavior you are describing.
Old Jan 15, 2013 | 02:04 PM
Mrmiata's Avatar
And a shortcut link in my signature to click on..
Old Jan 15, 2013 | 02:42 PM
STEPHENJXN's Avatar
Much Thanks to MrMiata for the link!
Old Jan 15, 2013 | 02:46 PM
Mrmiata's Avatar
Just here to learn and share what I learn.. makes life easier if I don't have to search it out for someone.. and keeps from posting "use search".. lol. 50 pages pull up and your trying to fix a problem..not spend a day with in depth reading.. LOL
Old Jan 15, 2013 | 02:49 PM
Was it a coincidence that the fob would not work, Hmm.
Maybe not.
If these symptoms are linked then the problem may lie in the security system.
Does the second fob open the door?
Have you got water in the trunk? That would be in the passenger side well under the Styrofoam block.
Old Jan 15, 2013 | 03:12 PM
Raptor's Avatar
Second fob would not work either.
Old Jan 15, 2013 | 04:16 PM
Mrmiata's Avatar
Maybe not.
Ahh... I read right past that "two starts and nada".. Disconnect battery..reconnect and try again..two more attempts and nothing.. then here we go time.. There's a rubber plug on the bottom of the car..rear of passenger location (under the styrofoam blocks mentioned).. "puncture" it and see if you get any water out of it.. The easy way to see if you have standing water right quick..
KDW4Him
18
Sep 1, 2021 05:47 PM
Bayukbros
Jul 17, 2015 04:22 PM
UrbanE
Jul 16, 2015 01:39 AM
66L72M21
Jul 15, 2015 04:23 PM
Fildo Dog
Jul 6, 2015 05:20 PM
