Electrical problem. HELP
Old Jan 15, 2013 | 06:04 PM
Crossfire725's Avatar
Default Electrical problem. HELP
This past 2 month my factory alternator started going I thought. My dash lights started to pulseate and my battery light would appear. So I changed it. It took 3 try's to order the right alternator. The backing a were always wrong and so on. It's been about a month I have had the new alternator and just yesterday when I was listening to music my lights dim and the abs bas light came on. Since then my light palseate at idle. I did a test with a volt meter to the back of the alternator and getting 13.2 - 13.6 while running. The lights were pulseateing at the time I was getting that reading. Recently thought I have been getting a code for my secondary air injection it comes and goes at random stays on for a day max. Could that be drawing power? I don't know if its another bad alternator or something else is up. My battery is from 6/11 which isn't that old. Is there a external voltage regulator or something. Or any ideas what is going on. Please pass along to someone that may have an idea if you don't. Thank you.
Old Jan 15, 2013 | 06:48 PM
Default Re: Electrical problem. HELP
Let's look at how the charging system works:
The alternator charges the battery directly thru a cable that (I am 99% sure) goes right from the alternator to the "hot" side of the starter solenoid. This connects to the cable that is the BIG positive battery cable that then goes right up to the battery. There MUST be a good ground path from the alternator to the battery as well, that is the circuit: From alternator, to battery via cables, then from battery thru it's ground cable, thru the chassis, thru the jumper from chassis to engine block, then from the block thru the alternator mounting bolts and into the frame of the alternator.
These alternators use an internal regulator, and the ONLY way they "know" what the battery voltage is, is via a LOW resistance path as described above. Any corrosion or "green" (that is, formerly wet and now corroded) connections will mess up the alternator's ability to charge.
Power for everything ELSE in the car comes from the battery, down the SMALLER cable from the Positive Battery post that goes directly to the four-fuse little box just ahead of the battery. Power is distributed to the entire car thru the three fuses (one position is unused) in that box. There are many paths taken from that box, section 8W of the manual diagrams this for you.
Perhaps the battery IS being charged just fine. Perhaps you have a poor feed of power to the car.
I would check for corroded battery posts/cable clamps and a corroded battery ground cable (look over CLOSELY the lug and screw where it attaches to the fender/etc., just ahead of the battery). ALSO, there is (somewhere, never found it myself) a heavy ground strap from the engine block to the chassis. On my car, I suspected this cable to be bad when I bought the car. I made up a piece of Number 6 insulated ground wire with two soldered lugs on it. One attaches to the negative battery post clamp, the other goes to a bolt on the engine block (can't remember which bolt I used and I'm 700 miles from home this week).
It was good for you to measure the alternator output. The next step WHILE IT IS DOING IT, would be to measure battery voltage. After that, go measure the voltage at, say, the cigarette lighter, or one of the fuses in the various fuse boxes. SOMEWHERE, you are seeing a drop in voltage that is "offending" or "confusing" one or more modules in the car - that is why the abs light came on.
If you come back telling us that the battery is at 13.5 or more but you only see, say, 11 volts on the cigarette lighter, or on some/all of the fuses in one or more fuse boxes, we can then start to trace where the problem is.
The air pump probably does draw 10 or 20 amps, but the car is DESIGNED TO SUPPORT THAT. If the pump coming on causes problems, it's not likely the pump is drawing too much, but instead that the system is in trouble and cant' support the normal load.
ONE MORE THING, My car's instrument lights flicker ONCE, every once in a while. I suspect I am soon to experience trouble for myself. It sounds to me like SOMETHING is turning on in my car and the system is barely handling it. But maybe not.....?
Old Jan 15, 2013 | 07:16 PM
waldig's Avatar
Default
From cold start you need to be seeing 14 volts@!!!woody
Old Jan 16, 2013 | 11:31 AM
i really respect the time you put into that response. a lot of respect for that. i got fed up today and i took it to the dealer for them to run a scan on it and see whats going on with the electrical system. they couldnt tell me anything, they said the system looks like its working correctly. they said the alternator output is correct. they suspected my woofer and amp i have in the trunk. i uninstalled all of that even the wireing behind the head unit i removed, removed all the grounds i used for the amp. and i am still getting the issue. i cleaned the terminals with a wire brush. still getting the issue. i disconnected the air pump figuring maybe it shorted out, and i still got the problem. i still want to measure the volts fron various fuses like you suggested before, but what i suspect next is possibly, i did my spark plugs about 2 months ago when the time my alternators started this pulsating issue and changing the alternator seemed to fix it for a period of time but then the same thing weeks later has happened. could it be a misfire that would be making this effect? or killing my alternators? i have the factory alternator still that i want to get rebuilt, cause maybe these aftermarkets are crap? or something else is killing them? or i am misfiring? i figured if it was a short or a bad ground? when i rev the car or driving cause the rpms are higher i do not come across these problems, WHEN I FIRST INSTALLED THIS NEW ALTERNATOR THOUGH I WAS GETTING 14.3 NOW I AM GETTING 13.6? am i getting unlucky with alternators or is something killing them or am i loosing power some where else. this is a head ache. i thank you all for the responses in advance.
Old Jan 16, 2013 | 11:32 AM
tcar32909
Aug 1, 2024 02:41 PM
nataliefs
Oct 5, 2015 01:03 PM
Charlesl
Sep 30, 2015 10:46 PM
Abaton6
Sep 24, 2015 10:14 PM
Wisconsinfdcrossfire
Sep 20, 2015 10:04 PM
