help crossfire speed sensor switch
Old Feb 17, 2013 | 03:59 PM
nashcrossfire's Avatar
Default help crossfire speed sensor switch
hi im new and only just got my 2004 crossfire automatic.
what I need to know is my car is not changing gear and the fault code coming up is(*P0715 Input/Turbine Speed Sensor Circuit Malfunction)
is there 3 sensors?
if so which one do I need?
has anyone got any pictures of the part needed?
can someone trll me where the cheap place to buy this part.
I live in London united kingdom.
thanks in advanced
Old Feb 17, 2013 | 04:21 PM
ChuckNorris's Avatar
Default Re: help crossfire speed sensor switch
That code usually points to a bad "conductor plate" in the trans. Here is a thread you should read
https://www.crossfireforum.org/forum...-problems.html
Old Feb 17, 2013 | 04:29 PM
thanks will have a look
Old Feb 23, 2013 | 10:23 AM
hey people's. im back.
ok so I changed the condutor plate and got the yellow plug also a new gasket and new atf and had thrm fitted.today the mechanic said that the car still the same. im so pissed right now.
he said the car knocks in to drive and still not changing gear.but he rang me yesterday and said that the bottom of my car was drenched in oil.which must of been the old gasket.
so where is the turbine speed sensor on the crossfire?
anyone got a part number please and even a picture.it can only be that right or?
Old Feb 23, 2013 | 11:04 AM
If you look at the picture in this post (click) you will see the parts that can cause the problem. The problem is called 'limp mode', the transmission stays in second gear only so as not to cause damage to itself.
The part consists of two parts screwed together, the electrical plate and the solenoid plate. Which part was replaced or were both replaced?
Old Feb 23, 2013 | 12:24 PM
I changed the trans conductor plate. filter . yellow plug and gasket
Old Feb 23, 2013 | 12:27 PM
by the way that pic didnt help. any one please
Old Feb 23, 2013 | 12:41 PM
Try this :
( note : the troubleshooting procedure for the P0715 is pretty involved, it starts on 21-92 of the 2005_Crossfire_SRT6_Service_manual.pdf that can be downloaded from the below links )
Old Feb 23, 2013 | 12:59 PM
ok thanks for that. Any one got a parts number please.i need to buy this part asap ebay or mopar
Old Feb 24, 2013 | 07:36 PM
If the code is not cleared properly the transmission will go right back into limp mode.
Lots more info here
Mercedes-Benz 722.6 Transmission FAQ - Benzworld.org - Mercedes-Benz Discussion Forum
Old Feb 26, 2013 | 10:18 AM
hey guys. i changed the condutor plate twice and still no change.i went to a crossfire dealer today and the guy put it on the computer for free for me.i think he could see how upset i was.now he came back with p0715 which could be wiring fault or condutor plate or transmission control module
i need to know a bit more about the module.
if i get a mudule on ebay will i have to get it programmed even if it came out a crossfire?
anyone got or had the same problem? if so how did you fix it?
Old Mar 10, 2013 | 05:51 PM
shadowin1986's Avatar
Your speed sensor should be plugged right into the top of your transmission. it has a pin that holds it in place,once you pull the pin out turn it clockwise then pull straight out and it will drop then unplug the connector and you've got it out and ready to be replaced.
Old Mar 10, 2013 | 07:21 PM
thanks for all the replys.i got it sorted . changed the transmission connector plate.then went to a automatic specialist. they then removed the p0715 code from a few modules and all is back to normal.if you live in the u.k london. visit mister transmission. they know what there doing.
Old Jun 23, 2013 | 12:35 PM
Daishan's Avatar
Could I ask exactly where you would suggest getting the Valve plate that has the sensors on it for code p0715? I don't want to end up with a crappy part, but I also don't want to spend $350. So, does anyone know of a reliable part for this?
Old Jun 23, 2013 | 07:00 PM
Skippy911's Avatar
Default
Hello sir.... I'm having the same problem read? Alright I've had a major issue since I bought my 05 Crossfire.. 1 month after I bought my car it would stall out in 1st or 2nd gear and I would Have to stop turn the car off and restart the car for it to drive correctly. 4 months later the same problem consist but now the car is stuck in 1st gear and will not shift... Also the check engine light is on and the codes I'm getting are p0715 & another code that says the tcm has malfunctioned I think it's p0705. Also I go to put the car in reverse and it jerks into reverse and I place it in D and it jerks into 1st then I drive it and the cars RPM's rev up and doesn't shift??? I unplugged the TCM and the battery but the check engine lights still on and the car still acts up.... What gives, pleasssse HELP?!?!
Old Jun 23, 2013 | 07:17 PM
Dumb question : Have you checked the transmission fluid level ?
Old Jun 23, 2013 | 07:23 PM
Skippy911's Avatar
Default
Alex... I Hv not checked the trans oil. What makes you think it's the culprit? Is it true only Chrysler can check the trans oil level? If in wrong pls let me know
Old Jun 24, 2013 | 07:31 AM
PNA's Avatar
PNA
The transmissions are sealed from the factory but they can be checked by removing a cap and then you'll need a certain length flexible plastic stem to check the level. There is a thread on here somewhere that describes the procedure. If you've lost fluid through a leak (possibly the transmission connector) then the car can go into limp mode and exhibit many of these issues. It's always best to start with the simpliist thing to check, which would be for leaks and fluid level. I'm not saying it might not be something else, but............
Even if you have to take it to a tranny / dealer, you should have the fluid level and connector checked.
Best of luck. I hope it's something simple.
Old Jun 24, 2013 | 07:54 AM
Or, you can get an 'official' tranny dip stick from fleabay :
http://www.ebay.com/itm/Mercedes-Benz-ML430-ML350-ML500-ML320-ML55-722-6-Transmission-Dipstick-Tool-/171057257031?pt=Motors_Automotive_Tools&hash=item27d3ce9a47&vxp=mtr
Old Jun 24, 2013 | 05:20 PM
Skippy911's Avatar
Default
Looking for pricing for a 2005 Crossfire 3.2 v6 non super chg electric conductor transmission plate online or anywhere near Dallas Texas
