Dashboard bipping! and noisy trunck
Old Apr 10, 2013 | 01:28 PM
maxime75us's Avatar
Default Dashboard bipping! and noisy trunck
Hi All!
Dasboard has been beepping for the past few days, high pitch beeps, 2 seconds, ten seconds. Whatever seconds you want, she does it.
Was wondering if one of you had the joy to have the same issue!
About the trunk, the hatchback is making noise, I know what it is, these two little pieces of foam/rubber. I JUST DON`T know where to buy it.
Thanks again for your help
By the way, The Michelin Pilot Super Sport tires are just beyond greatness.
Cheers,
Max in Houston
Old Apr 10, 2013 | 02:52 PM
Alabama Crossfire's Avatar
Default Re: Dashboard bipping! and noisy trunck
Can't attest to the dash noise. My hatch was making some noise when I would hit some road bumps and I used self adhesive foam to place under the "feet" of the hatch stops and it seemed to cure the hatch issue. I'm assuming the noise from the dash may be either the dash panel is loose or rubbing against an adjacent panel like the A pillar or something
Old Apr 10, 2013 | 04:09 PM
acrispy1's Avatar
When do you notice the beeps starting? Is your spoiler working correctly? if it isn't you will hear high pitch beeps starting at around 60mph, when you drop blow it will stop.
Old Apr 10, 2013 | 05:58 PM
MoparFreak69's Avatar
My roadster dash creaked when going over bumps. Removal of the defroster vent and tightening of the screw below it cured that problem.
As far as beeping, is your park brake handle all the way down? Any other indicator lights on the dash while it beeps?
joethejeweler
Jul 7, 2015 08:58 PM
cojoman
May 30, 2015 09:43 AM
alipsa
Apr 23, 2007 08:27 PM
ror0
Dec 6, 2006 11:15 PM
