overheating-cooling fan not working
Old Aug 2, 2013 | 01:12 PM
sbonney's Avatar
Default overheating-cooling fan not working
My 2005 Crossfire overheated for some reason and blew a hole in the top of the plastic reservior. I had to replace the radiator as it crapped out, but havent got a replacement reservior yet.
Now the car is still overheating, but the temperature gauge does not rise.
Car is still overheating due to coolant being forced out of the broken reservoir..
The cooling fan does not come on but The AC compressor does come on - doesnt cool as it should though.
Any ideas?
Old Aug 2, 2013 | 02:28 PM
Default Re: overheating-cooling fan not working
Look on Car-Part.com--Used Auto Parts Market for the overdlow bottle ( that's what it is called there )
There are many reasons the radiator fan won't run :
1. bad fan controller
2. bad fan motor
3. bad wiring/connections
Unplug the fan connector and connect 12v from the battery to the 12v fan wire, and a ground to the ground connector.
( BE VERY CAREFUL TO NOT TOUCH YOUR 12V AND GROUND WIRES TOGETHER - YOU HAVE BEEN WARNED !!! )
If the fan runs then it's the other stuff.
The PTCM controls the fan control module digitally to set different fan speeds, the first thing to check is that the big fat 12v wire going into the fan control module actually has 12v on it.
waldig
Sep 2, 2015 11:02 AM
hhr hellshotrod
Aug 17, 2015 11:27 PM
BrenLW
Aug 4, 2015 01:29 PM
waldig
Jul 15, 2015 02:05 PM
joethejeweler
Jul 7, 2015 08:58 PM
