Front to rear hatch divider(behind the seat)
Old Jan 22, 2014 | 01:37 PM
B1gfun's Avatar
Default Front to rear hatch divider(behind the seat)
What is this called so I can further do some searching? Or if anyone has a qucik link on how to open it up. I want to take it apart in the future to possibly add different subs. I have searched the audio section and found pages of irrelevant info into a dismantle. Thanks in advance!
Old Jan 22, 2014 | 01:48 PM
Default Re: Front to rear hatch divider(behind the seat)
Take a cutting torch to it and near the bottom of it you will stumble briefly on the gas tank, a real WTF moment in your shortened life.
This bulkhead supplies rigidity to the chassis.
Old Jan 22, 2014 | 01:52 PM
B1gfun's Avatar
Aaaahhh! SMH Guess I wont be able to increase the depth or build a box in it. LOL!
Old Jan 22, 2014 | 02:22 PM
Padgett's Avatar
l took the top 6 inchesish off to allow the seat to recline further. It does not go all of the way across so not structural (suspect it iwas a attachment bar for the SLK retractable mechanism that was never removed.
In any event removing the top 4" (down to the second horizontal) allowed my seat to go back an inch farther when reclined.
Old Jan 22, 2014 | 02:30 PM
B1gfun's Avatar
Got a pic of the finished product?
Old Jan 22, 2014 | 02:52 PM
I always think a picture is worth a thousand words.
Old Jan 22, 2014 | 03:00 PM
B1gfun's Avatar
Do you have pick from the rear looking front?
Old Jan 22, 2014 | 03:30 PM
Go here ......
Old Jan 22, 2014 | 03:33 PM
B1gfun's Avatar
Thanks 180!!! U DA MAN!
My dreams of building a box in that are squashed!
Old Jan 22, 2014 | 05:51 PM
Padgett's Avatar
180's pics are the best I've seen but here is what the seat looks like installed (I didn't remove the seats just moved forward and out of the way, also just modified behind the driver's seat, that is a nice and complete job. I would remove the rear wall down to that level if going that far. You do not have a tonneau that needs to register on it.
Note: the seat rails were also raised 1/2" (if the wheel don't tilt...)
Old Jan 22, 2014 | 06:23 PM
The pic I show of the bulkhead from the front is wrong, I think that is a modified one. I looked at it again and it is not the way the OEM chassis is built. There is about a 8" above that. There is another pic that shows it better but not so close.
File Type: jpeg
Old Jan 22, 2014 | 07:05 PM
Padgett's Avatar
That's what I meant, your picture shows the bar very nicely removed (can see the shart/shiny edges on the passenger side and shows where the original bar was.
The picture below shows the edge of the removed box section looking back from the driver's window (and what I removed).
As you can see, the beam stops well short of the side of the car and adds little to any torsional stiffness.
Old Jan 22, 2014 | 07:30 PM
Look at that lovely OPEN channel in the frame below the doors.
Should be some way to use that for a cold air intake, or for a rear turbo ( which I guess is impossible )
Old Jan 22, 2014 | 08:55 PM
Padgett's Avatar
This may make the difference clearer and show how far down it can be cut. Note where the speaker hole is in each. OTOH it almost looks like the stampings are reversed. Curious.
waldig
Jul 30, 2015 07:39 PM
pioneer4x4
Jul 27, 2015 02:04 PM
Jerrysrt6
Jul 24, 2015 09:15 PM
rmcdaniel12
Jul 21, 2015 11:35 PM
axnguyen
Jul 21, 2015 11:41 AM
