Both ear drums busted...
Old Feb 28, 2014 | 10:49 AM
Number1sith's Avatar
Default Both ear drums busted...
Ok fellas i hit an all time low today. I wanted to disconnect my battery just to eyeball the RCM and right as I lift the negative terminal off the battery the alarm goes off and my baby starts acting like she doesn't know me anymore and just keep crying till i reattach the damn thing, how to i properly disconnect/reconnect this 2005 prom queen's battery without offending it?
Old Feb 28, 2014 | 10:59 AM
maxcichon's Avatar
Default Re: Both ear drums busted.....
Make sure it isn't locked? It thinks you're stealing it.
Old Feb 28, 2014 | 11:35 AM
I never disconnected the battery to remove the RCM, never had any problems.
I've probably had it out 15 or so times for one reason or another.
( I swap in RCM's that I have repaired to test them ( like tighed1 ) )
Old Feb 28, 2014 | 11:43 AM
Default
disconnect not remove sorry
Old Feb 28, 2014 | 11:47 AM
That's what I'm saying : I don't TOUCH the battery at all.
( but maybe I'm just lucky, don't take this as advise, the SAFE route is to always disconnect the negative battery terminal before doing anything electrical )
Old Feb 28, 2014 | 12:05 PM
<p>Ok battery done. Unplug everything from RCM gotcha. After replacing all the relays should I replace those top fuses as well?</p>
Old Feb 28, 2014 | 12:06 PM
Default
good thinking batman I just had to be quicker is all :P
Old Feb 28, 2014 | 12:58 PM
RL67037's Avatar
Fuses are normally good or bad - no in between on them. If the fuses are good, there would be no reason (that I can think of) to replace them.
Old Feb 28, 2014 | 01:23 PM
Replacing the RCM relays is not for the faint of heart, or an inexperienced electronics technician with the proper un-soldering equipment,
besides, the only relay that should even NEED replacing is the secondary air pump relay.
All you should be concerned with is cold solder joints ......
What is the original issue that is causing you to eyeball the RCM ?
Old Feb 28, 2014 | 01:38 PM
Default
the secondary air injection issue. I bought enough relays to replace all five and was gonna also pick up some fuses. But I have no experience in soldering. I'll go visit this R/C hobby shop tomorrow by my house to see if they might be able to do it. only issue left till im roaring on the road
Old Feb 28, 2014 | 01:41 PM
OK, just worry about the air pump relay, never heard of any issue with the others.
Send your spares to tighed1 if you want to help other forum members
Old Feb 28, 2014 | 02:03 PM
Default
<p>
OK, just worry about the air pump relay, never heard of any issue with the others.</p>
<p>Send your spares to tighed1 if you want to help other forum members
</p>
<p>&nbsp;</p>
I ordered 9 since im on a budget , think he'll be able to fix my rcm up? I'd appreciate it immensely. i just don't know anyone who will be able to handle that type of thing with precision
Old Feb 28, 2014 | 02:31 PM
Look in the yellow pages for a Motorola/Kenwood radio shop. They should have SOMEONE who can solder. Even if they charge you an hour, most areas, that would be $75 to $90.
Or box it up and send to me, Ala_x or Tightd1.
Old Feb 28, 2014 | 02:35 PM
tighed1 ( DJ ) will probably do it free if you include the relays, he usually charges $25 for the relay replacement.
He'll also maybe throw in the "Me So Horny" mod
Old Feb 28, 2014 | 02:37 PM
Default
that sounds fun, what is that??
Old Feb 28, 2014 | 02:38 PM
Default
any of Y'all in Tejas? Lol
Old Feb 28, 2014 | 02:39 PM
It allows you to blow the horn without having to turn on the ignition.
BTW, tighed1 is in Sierra Vista, AZ
wld1985's Avatar
Im looking for someone to repair my rcm,and look it over. I tried to solder it. But it kept blobing so i quit.
Old Feb 28, 2014 | 02:40 PM
1. tighed1
2. pizzaguy
3. me ( alaxfire )
or another possibility : DAY TRIP !!!!
You are ONLY 247 miles from me, I'll be here all weekend.
Old Feb 28, 2014 | 02:45 PM
wld1985's Avatar
I sent a pm to tighed the other day, mom wants her car back and i want to make sure its fixed before i take it back to her.. Can you send me ur info,the cost and ur paypal email and ill send the money over as gift..
