Headlamp Off Time Delay
Old Jan 14, 2015 | 02:30 PM
DJ Dax's Avatar
Default Headlamp Off Time Delay
Hi Guys and Girls ..I believe my Xfire has Headlamp Off Time Delay but I have never used it and don't know how to is it adjustable and does it work automatically. Any advised would be gratefully received...Thanks in advance.Dax
Old Jan 14, 2015 | 03:18 PM
Default Re: Headlamp Off Time Delay
My Limited does not keep the headlights on for a delay, it keeps the fog lights on.
Perhaps you have a base model that does not have fog lights ?
Old Jan 14, 2015 | 03:37 PM
chrisificti0n's Avatar
My base model does not turn off the headlights if you leave them in the on position until the battery dies. No fogs to speak of, but this isn't a feature I was aware of the crossfires having at all.
Old Jan 14, 2015 | 03:59 PM
DJ Dax's Avatar
Hi Guys thanks for the replies..I have fog lights as standard the Xfire was built for the UK. I have looked at the specks and it says that the car was built with the Headlamp Off Time Delay option ..Thanks Guys
Old Jan 14, 2015 | 04:04 PM
DJ Dax's Avatar
Hi Guys below is the vehicle Description
Vehicle Description 2004 CHRYSLER CROSSFIRE-RWD RHD TWO DOOR SPORTS
COUPE
Monotone Paint
Brake Assist
Electronic Stability Control
Traction Control
Anti-Lock 4-Wheel-Disc Brakes
Supplemental Side Air Bags
Driver & Front Passenger Air Bags
Carpets - Floor and Cargo Area
Front Floor Mats
Door Sill Scuff Pads
Heated Front Seats
Soft Door Trim Panel w/Map Pockets
Floor Console w/Cupholder
Storage Pocket
2.7 Overall Top Gear Ratio
Tinted Glass Windows
Tinted Windshield Glass
Rear Window Defroster
Rear View Auto Dim Mirror
Sun Visors w/Covered Vanity Mirror
Power Heated Mirrors, Fold-Away
Keyless Entry
Sentry Key Theft Deterrent System
STANDARD EQUIPMENT
1 01/13/15
Air Cond'ing w/Dual Zone Temp Cntrl
Premium Insulation Group
Instrument Panel
Instrument Cluster w/Tach
Intermittent Windshield Wipers
Cigar Lighter
Dual Note Electric Horns
Locking Glove Box
Power Accessory Delay
Air Filtering
Power Auto Central Locking Locks
Pwr Windows, Front 1-Touch Down
Power 8-Way Driver/Passenger Seats
Illuminated Entry
Low Washer Fluid Warning Signal
Glove Box Lamp
Front Courtesy/Map Lamps
Cargo Compartment Lamp
Halogen Projector w/Delay Headlamps
Fog Lamps
CHMSL Lamp
Front Wide License Plate Bracket
Body Color Fascias
Satin Door Handles
Decklid Chrysler Wing Badge
Grille Chrysler Wing Badge
Crossfire Badge
Rear Active Spoiler
2 01/13/15
Export Emissions
Dual Bright Exhaust Tips
15.9 Gallons Fuel Tank
Exterior Mirrors w/Heating Element
Speed Control
Graphite Metallic Clear Coat
AM/FM Compact Disc Radio
6 Infinity Speakers w/Subwoofers
240 Watt Amplifier
Integrated Window Antenna
Power Steering
Leather Wrapped Steering Wheel
Touring Suspension
Front and Rear Stabilizer Bars
Telescoping Steering Column
225/40ZR18 255/35ZR19 Perf Tires
18X7.5 19X9.0 Aluminum Wheels
Tow Hooks
Tire Service Kit
Universal Garage Door Opener
Locking Fuel Filler Door
Owner's Manual
Build To Export Mkt. Specifications
Export Homologated
Zone 06-Export
Retroactive Cost Adjustment I
Retroactive Cost Adjustment II
Right Hand Drive (RHD)
Price Class S
3 01/13/15
Two Door
Vehicle Order Tracking
Export Specifications Label
Leather Trimmed Bucket Seats
Dk Slate Gray/Med Slate Gray
European Equipment Group
Emergency Kit Group
Side Front Door Air Bags
5-Spd Auto W5A330 Transmission
AutoStick (R) Automatic Transmission
3.2L V6 SOHC 18 Valve Engine
160 MPH Primary Speedometer
Tachometer
Headlamp Leveling System
Rear Fog Lamps
Deluxe Security Alarm
Euro Stage 4 Emission Vehicle
Michelin Brand Tires
English/UK Language
Brake/Park Interlock
First Aid Kit
Reflecting Triangle
FAM: ZH TRACKING: 30520S07 MY:2004
FAM: ZH TRACKING: 30827S08 MY:2004
FAM: ZH TRACKING: 30930S03 MY:2004
Customer Preferred Package 2DA
OPTIONAL EQUIPMENT
4 01/13/15
Customer Preferred Package 22A
Intl. Price Protection B
Coso Wt. & D.M.
Market Homologation
Export Ocean Freight
Export Insurance
1NTL 37 DAY SCHEDULE
Special Scheduling Condition I
Special Scheduling Condition III
Export Option Requirements
Certificate of Conformance
Manufacturer Body Plate
United Kingdom Country Code
Western Europe Region Group
EMEA Region (Europe)
Old Jan 14, 2015 | 05:33 PM
Yep, that's a Limited, the fog lights should remain on for 30-45 seconds after key off.
Old Jan 14, 2015 | 06:27 PM
DJ Dax's Avatar
Thanks ALA.Do the fog light have to be switched on for this function to work.Dax
Old Jan 14, 2015 | 06:42 PM
Not that I recall, I'll go see.
EDIT :
In my dark garage, I started the car with the driver's door open, turned on the headlights, then turned off the headlights, then the ignition.
All that stayed on was the dome lights.
As soon as I shut the driver's door, the fog lights, the 2 little eyebrow lights, all four side running lights and the tail lights came on and
stayed on for 35 seconds.
( when you turn the headlights off, the switch automatically is cammed in and to the fog off position )
Old Jan 14, 2015 | 06:57 PM
DJ Dax's Avatar
Hi ala thank you.I will try that in the morning...Fingers crossed it will work on mine..Thank again . Dax
Old Jan 14, 2015 | 07:27 PM
maxcichon's Avatar
If you use any of the light switch positions, the delay feature is activated. If you haven't, they do not come on.
At least on mine. 2005 Limited Roadster.
Right?
Old Jan 15, 2015 | 07:35 AM
Right?
From my experience, I agree that that is the case.
Old Jan 15, 2015 | 12:18 PM
maxcichon's Avatar
Well, I guess I got THAT one right.
Old Jan 15, 2015 | 02:17 PM
not to change the subject but your spects say 2.7 final gear ratio,, please recheck this or send me your differential and tcu and i will send u one with 3.07 diff, and a 3.56 final gear ratio just kidding,,, but please check with a 2 something you should get 35 mpg jim
Old Jan 15, 2015 | 02:34 PM
maxcichon's Avatar
Jim,
is that the spec for the transmission final drive (Top Gear 5A/6M)?
Old Jan 15, 2015 | 05:46 PM
sorry opened my moth before knew what to say LOL ,,here is the tranny and rear ratio
Transaxle: Manual, Six-Speed Overdrive Automatic, Five-Speed Overdrive Description
Synchronized in all forward gears
Adaptive electronic control or AutoStick® driver-interactive manual control and lockup torque converter clutch
Torque Converter Stall Torque Ratio
1.8
Gear Ratios
1st
4.459
3.95
2nd
2.614
2.423
3rd
1.723
1.486
4th
1.245
1.000
5th
1.000
0.833
6th
0.838
Reverse
4.062
3.147/1.93
Final Drive Ratio
3.27
3.27
Overall Top Gear
2.74
2.74
Old Jan 18, 2015 | 11:14 AM
Nokke's Avatar
So is there place to activate that light off time delay? or is there some kind of set of actions to get in on? Example on 300M, first need to turn car off and after that turn lights off from light-switch, then headlamps stay on for about 30 secs
Old Jan 21, 2015 | 04:05 PM
AlG's Avatar
AlG
The way to not have the fog lights turn on after you shut off the car is to lock the car with the fob BEFORE you shut the driver's door. Then close the door and lock the car again because the door won't lock while it's open. Learned that from a thread here on the forum.
Old Jan 21, 2015 | 04:52 PM
Nokke's Avatar
ok, thx. so I don't have headlights off time delay -option....
ZERACER
Jul 7, 2020 10:21 PM
waldig
Jul 31, 2017 09:46 AM
Aug 3, 2015 10:16 AM
waldig
Jul 30, 2015 07:39 PM
Ralph289
Jul 26, 2015 12:52 PM
