2004 Crossfire coupe limited
Old 11-20-2015, 03:40 PM
smokey1969's Avatar
Angry 2004 Crossfire coupe limited
I am going to buy this crossfire only 20000 miles but I need advice, It has a heater or air conditioning problem .It does not know to blow heat or when to blow cold air. It can't be controlled with switches. Need help where to look. It was owned by an old man sat still mostly.
Old 11-20-2015, 03:50 PM
Default Re: 2004 Crossfire coupe limited
either the fan resistor module or the ac/heat control module.
There are stickys on here for both of those.
the resistor module, you replace, the ac/heat module you dissemble and fix the pin contacts.
https://www.crossfireforum.org/forum...speed-fix.html
and
https://www.crossfireforum.org/forum...-resistor.html
Old 11-20-2015, 04:50 PM
I have news for you, at 64 you are an old man, just not as old as some. With some luck you may get there as well.
amx1397
Other Vehicles
07-24-2020 09:25 AM
Jonacross
20
07-17-2017 11:19 PM
massanu
18
11-23-2015 08:52 AM
jimf
19
10-19-2015 04:05 PM
psuperti
08-30-2015 12:08 PM
Quick Reply: 2004 Crossfire coupe limited
