AC/Heat
Old May 9, 2016 | 02:38 PM
oldtimer48's Avatar
Angry AC/Heat
AC only blows hot air. Fuses are good All suggestions appreciated....Thanks
Old May 9, 2016 | 03:14 PM
Steve Jr's Avatar
Default Re: AC/Heat
Is AC compressor clutch engaging?
Old May 9, 2016 | 03:44 PM
2004_'s Avatar
Default Re: AC/Heat
Do you have freon?
Old May 9, 2016 | 04:46 PM
Default Re: AC/Heat
Sounds like another Duovalve failure.
MOST complaints of a Crossfire (and many Mercedes) blowing hot air with hte A/C on are not A/C failures, they are duovalve failure. The duovalve is the gate thru which hot water flows to the heater cores. Unenergized = full flow and hot air. SOmehow, they tend to stick OPEN not closed.
Watch the video:
Old May 9, 2016 | 04:49 PM
Default Re: AC/Heat
To make myself clear, A/C blowing untreated air is an A/C failure. A/C blowing HOT air is most often a duovalve stuck open. If the air just untreated, outside temperature air or is it HOT? Does turning the temperature wheels have NO effect? If so, it's the damn duovalve.
Old May 10, 2016 | 12:16 AM
Default Re: AC/Heat
Watch the video:
How to..Mercedes monovalve, duo valve cleaning,checking - YouTube
It is a 'failsafe' that the valves are open when coils are de-energized.
Old May 10, 2016 | 08:35 AM
oldtimer48's Avatar
Smile Re: AC/Heat
Thanks to all who offered valuable information. I'll be looking all of the possibilities.
Apr 24, 2016 12:17 PM
JCostakis25
Apr 23, 2016 08:18 AM
DCobray
Jun 19, 2011 02:59 PM
Louie K
Aug 29, 2009 01:37 PM
drhrsh
Apr 11, 2005 09:22 PM
