What's involved witht he First Gear syncro fix?
Old Apr 7, 2005 | 08:06 PM
ViffeR's Avatar
Default What's involved witht he First Gear syncro fix?
The dealer has finally agreed to fix my first gear issue and says they have to order a syncro kit in inorder to repair it. Does anyone know what is technicalls involved int he repair and what parts are replaced/adjusted?
Is there any way I can be sure the parts were actually installed? Are there any tell tale signs of the work being completed?
Old Apr 7, 2005 | 08:18 PM
aschrager's Avatar
Default Re: What's involved witht he First Gear syncro fix?
If you don't trust the dealer you should go to another one.
Old Apr 7, 2005 | 09:24 PM
xfire embrace
Guest
Posts: n/a
Smile Re: What's involved witht he First Gear syncro fix?
Bring along a/some friends that are familiar in the field and get 2nd and so forth, assured opinions.
All the best.
Old Apr 8, 2005 | 12:56 PM
knowit's Avatar
It is a huge job. The tranny must be dropped and then completely dissassembled and then put back together correctly. They had mine for five days. I notice no difference although mine never jumped out of gear. Just real hard to get it into first sometimes. I thought the syncros would fix that. I was wrong. Good luck.
Old Apr 8, 2005 | 06:05 PM
ViffeR's Avatar
As much as I would like to avoid any major work on my car (like dropping the tranny) I am glad it is getting fixed. It probably pops out of gear an average of 3 times per day, and that is just commuting to and from work. I will be nice to ba able to drive the car without having to cringe when using first gear all the time...
Old Apr 8, 2005 | 06:50 PM
Gene12's Avatar
I'm just curious. What is the build number of your car as the first gear issue is associated mainly with cars built before Dec '03?
Good luck with the fix.
Old Apr 8, 2005 | 10:00 PM
ViffeR's Avatar
Build number 5454 I believe the build date is August 2003...
fastfred
Nov 5, 2018 09:47 AM
Steven 4190
Nov 25, 2015 10:12 AM
jimf
Oct 10, 2015 10:22 AM
Oct 1, 2015 01:42 AM
rfourt
Sep 25, 2015 01:38 PM
