Which panel to open? Help
Hi all. This is a question for those of you who have replaced their SKREEM module in their 2008 Crossfire. I’m trying to do that but can’t figure out which panel to take out.
1. See photo #1. Is this the correct panel to take out (see red arrow). This is the entire bottom panel.
2. If so, see photo #2. Do I need to unscrew these? It seems impossible to take the bottom panel out without also taking these screws out.
I’m not a handy person. Help!
Mike
Mike
Thanks guys for the video. It is definitely what I needed but the video is for earlier models. The panel did change for 2008. Since I’m not really handy this will be a challenge but I will give my best shot on it. I will report back on how it went and try to contribute for others like me.
This will only allow you to remove the halo, you still need to remove the SKREEM module itself and that is explained in some posts here and in the Service Manua,
It involves moving aside the Instruement panel.
Not sure but the ones with knee air bags will be different, the Crossfires with the key problem were earlier years as stated.
Download the service manual. It’s a lot easier to do once you’ve reviewed the steps
Buy a set of trim tools from Napa or other for about $7.00
This and time would be your only expense. Of course utilization of a shop that doesn’t know a whole lot more than you do know is always an option.
Trickle down economics
The shock of the labour rate to change it out will trickle down on your wallet for days.
Most service techs are in a hurry due to allotted time per project. This is when stuff gets broken. You do not need to remove the wheel or airbag to do this
It’s just time and patience. If you go the pro service route, at least download the manual and educate yourself on what’s required so that you don’t get talked into doing a load of crap that has nothing to do with your requirement.
I saw this happen recently with a shifter replacement and console lock for another member. The shop kept going on about reprogramming a part that was essentially plug and play.
Knowledge is the key to ensuring it gets done correctly by others
We’re here to support your decision either way
There is no need to remove the steering wheel as it says according to hose who have done it before.
https://www.repairmanuals.co/8524736...SABEgK5FfD_BwE
Thanks.
Look at the Service Manual as stated and then you will see these views. CLICK
You can download a PDF file of the Service manual from this very site for FREE.
I don’t know if you folks are referring to the parts manual but I’m aware of the link and I do not see any service manual for 2008. I’ve seen ones for earlier models. I must not be seeing what’s obvious to everyone else.....
There are 2004 and 2005 Service Manuals and they cover all years in general.
However, convertible top info is only in the 2005 SRT6 manual.
SKREEM = Sentry Key Remote Entry Module
Your key fob has a non powered 'chip' in it, when the ignition is turned on the SKREEM causes the halo key ring antenna to excite it, then monitors the frequency generated.
If the frequency is correct the SKREEM signals the PCM ( Powertrain Control Module ) that all is well and it may proceed with the complete start procedure.
