What part number pease help me out
Old Dec 4, 2018 | 01:23 PM
DavieBoiii's Avatar
Default What part number pease help me out
Hi friends
I have a little tricky situation. Just bought me a crossfire cope year 2007 with a little DIY.
It is missing the cars computer I think it is. It is supposed to be under the hood next to the RCM.
it should be in the center in the fuse box.
I need to know what part number I can find one used. I don't want to order wrong part by mistake
I thin I need to buy also one j2534 pass thru so I can reprogramming it to fit my car. I want to buy the best j2534 so I can use it with as many cars as possible for the future. Any recommendations?
thank you so much for helping me. I will wait patiently for any answers
// David
I think it is the PCM but I don't know what part numbers to order so I don't get the wrong one. It is in the center next to RCM
Old Dec 4, 2018 | 01:40 PM
Default Re: What part number pease help me out
In the box where the RCM is located, it's RCM, then BCM, then ECM ( or PTCM )
BCM is 05136131AA
PTCM (ECM ) is 05101505AA
RCM is 05099007AA
all this from the old parts manual, most have probably been superseded during production.
I know nothing about s j2534 pass thru.
I do know the BCM is VIN coded.
Old Dec 4, 2018 | 01:54 PM
DavieBoiii's Avatar
Thank you so much for the fast answer!
I am pretty much sure it is the center one. Do you know what is the mart code in mercedes part?
or is there only the Mopar part code I can go after?
I will rush out and take a photo how it looks under my hood. So I don't get the wrong part. 30 min and I will post a photo of it!
appreciate your time and help!
Old Dec 4, 2018 | 02:17 PM
DavieBoiii's Avatar
Here is the photos I just took.
Old Dec 4, 2018 | 06:04 PM
DavieBoiii's Avatar
I think I have found the right part number. And I also think it is the PCM that is missing in my car but I am not sure. Need confirmation. I will buy one from eBay and reflash it.
I found it with 2 different part numbers.I think it is the same part only with different numbers.
can anyone confirm that this 2 part numbers is the same item?
first number is:
A1121536579
and the second one is:
1705451240
the second one I find in better prices. Please confirm that it is the same part. After that I will make my order.
Old Dec 4, 2018 | 10:59 PM
first number is:
A1121536579
1705451240
It will be the one starting with the numbers 170
Old Dec 5, 2018 | 06:41 AM
DavieBoiii's Avatar
but are not the 2 parts identical to each other?
Old Dec 5, 2018 | 09:36 AM
first number is:
A1121536579
1705451240
If it is identical why would there be two part numbers?
Old Dec 5, 2018 | 12:48 PM
DavieBoiii's Avatar
that is true. But you are sure about what you are saying. I have a 2007 crossfire coupe whith manual transmission.
just dont want to get the wrong one. Thabks for helping me out!
Old Dec 5, 2018 | 05:04 PM
I’m not sure of anything, but you say you can reflash it so better you start with one from the 170 series cars.
Old Dec 6, 2018 | 04:04 PM
DavieBoiii's Avatar
I was at the junkyard collecting 3 pcm from different MB Cars. 2 of them has almost identical numbers to the crossfire part numbers.
The 3 different pcm has part numbers:
A 112 153 66 79
A 112 153 26 79
A 026 545 47 32
Maybe anyone can be good of these? I will solder new 5p08c to it if it is matching. Then need immo from somewhere and purchase tool to program the IC chip with.
I bought the car and it is missing the PCM and I don't know how to figure out which is the right part number
should I call chrysler or how can I know what is the right part.number so I don't order wrong one. And where can I get a immo dump of original PCM.
my car is just rusting away and I can't go forward (
please help me out. Can talk on Skype or was app for faster progress.
Old Dec 6, 2018 | 05:21 PM
Go here and go to manuals and then crossfire parts/electronics. You may find what you need.
Old Dec 7, 2018 | 06:14 AM
DavieBoiii's Avatar
Thank you for the link to that site. Everything in one place
I have MOPAR part code for 2007 and 2008 ecu that should both fit what I can understand. But I can't find the 2 codes I MB cross reference.
Mopar code:
2007 CPM: 05179831AB
2008 CPM: 68027422AB
Old Dec 7, 2018 | 07:21 PM
CL770's Avatar
Hi David
I'll PM you, Mercedes part number A1121535379 (Bosch 0261208425) will work, but it's not as simple as you think.
Masterwarren
Oct 3, 2018 07:01 PM
dom03
Aug 23, 2014 01:21 AM
Hurricane
Sep 8, 2012 06:37 PM
ohnoesaz
Jul 22, 2010 11:52 AM
SRT6nTulsa
Aug 10, 2008 03:27 PM
