Still wind noises
Old May 20, 2005 | 09:11 PM
chxf's Avatar
Unhappy Still wind noises
I just had my xf at the dealer to fix the wind noises. But I don't think there's any difference. Although he said he's mounted new seals and fumbled around the small triangle in the front.
In this forum I read from some who let it do as well and came off. Do you remember what has been done?
Thanks.
Old May 21, 2005 | 12:57 AM
Cyril Baldwin's Avatar
Default Re: Still wind noises
They can never fixed it so you have to do it yourself. Here's how I fixed mine....go to AutoZone and buy their 1/2 inch insulation and insert it behind the stock rubber insulation. That fixed my door popping and wind noise problem! I've been to the dealership 3 times and they cannot fix it!
Old May 21, 2005 | 11:14 PM
chxf's Avatar
Thank you for your advice. As I'm from Europe I have not much access to AuroZone unless I sign up. Therefore I'll check our shops. Now my questions: what insulation did you buy? does it concern stock rubber insulation for the door? did you put it all the way behind the stock insulation or just partly? Is the stock insulation glued?
Thanks
Old Nov 8, 2005 | 08:49 PM
mromay's Avatar
Did you get your answers...if you did PLEASE tell me!!!
Old Nov 9, 2005 | 04:39 PM
cfire's Avatar
Question Re: Still wind noises
was your wind noise on the passenger side? Is there a procedure on doing this?
Old Nov 9, 2005 | 04:48 PM
mromay's Avatar
Has anyone had luck using the 1/2 inch AutoZone weather strip? If so could you please give details on how you installed it. I mean act like you are explaining it to a six year old!!! Pics would help. I love my 2004 Xfire...but the driver side wind noise is very unsettling. I have taken it two dealers...one...new weather stripping...second one...couldn't find anything wrong and actually suggested that the car had been wrecked. Bottom line...WIND NOISE.
Old Nov 9, 2005 | 09:52 PM
Buy this 1/2 inch weather strip from AutoZone or any store that sells weather strips for cars. If you run your fingers behind the rubber insulation of the window pillars you can feel a gap there which is about the same size as the 1/2 inch weather strip. Just insert the 1/2 inch weather strip to fill the space behind the rubber and that will solve your wind noise problem.
You will never get rained on anymore whenever you drive through a brushless car wash. I hope I explained it as simple as I can. Good luck!
Old Nov 11, 2005 | 08:01 PM
chxf's Avatar
Cyril, thanks once more for the infos. Will report how succeeded.
Greets
Old Dec 31, 2005 | 02:00 PM
Irafatsar's Avatar
on the side or across the entire top? also has anyone's seal started to crack on the joint where it turns down towards the front?
ty_ty37
Jun 27, 2024 10:42 AM
2005 Ragtop
Oct 3, 2015 03:01 PM
Oct 1, 2015 01:42 AM
pop49
Sep 30, 2015 11:14 AM
RacerXofFL
Sep 15, 2015 05:00 PM
