'03 coupe - Won't start. Help Needed
Old May 24, 2020 | 09:34 AM
Candyman's Avatar
Default '03 coupe - Won't start. Help Needed
Hello fellow Crossfire Owners.
I am in need of your assistance and expertise.
I have an 03 Crossfire Coupe that doesn't get used very often (only 24k miles). I went to start her up, turned the key and absolutely nothing happened. All of the dashboard lights came on as usual but the engine would not even start to turn over (no engine response at all other than the fan came on full but the car would not start).
I called the RAC recovery. They checked the fuses. All okay. Checked the battery, which was perfectly healthy. Connected the diagnostic computer but he kept getting "no connect/no response" errors so he could not run the diagnostics. He believed there is an issue with the car computer and said that it will need to go to a garage to be fixed.
Has anyone experienced this before? There are 3 units in the box next to the battery but I don't know what one could be faulty. I obviously don't want to buy reconditioned parts at £200+ each if they are not needed, so with your help you can tell me what part I need to buy or what I can do to fix it..
Thanks in advance for any help you can offer.
Old May 24, 2020 | 10:30 AM
Default Re: 03 coupe - Won't start. Help Needed
https://www.crossfireforum.org/forum...-no-start.html
if u can replace it ,,, but try the repair first there have been many (over 50) members, including myself, repair theirs but it still does not work,and they say something else is the problem once they put in a knowen working rcm it works, good luck.
Old May 24, 2020 | 10:32 AM
It is not always the solder joints. At that age it can also be the relays. Very easy to change, plug and play. I always carry a spare RCM.
Old May 24, 2020 | 11:16 AM
tighed1's Avatar
Guys. Remember me?!
Candyman. No need to spend the $$$ to buy a new RCM when it can be repaired for a lot less.
I can replace the bad engine control relay that is causing your problem.
Email me at tighed1@hotmail.com for the details on getting your RCM refurbished.
Old May 24, 2020 | 01:17 PM
The only reason I did not recommend you is because he lives in London,
Old May 24, 2020 | 03:36 PM
That is the way to do it, carry a spare.
I put my used spare in to see if it worked and left it in. The original one is in the trunk.
If you are handy you can put a new relay in yourself, details are on this forum.
Old May 25, 2020 | 12:22 AM
Candyman's Avatar
Thanks for the advice.
can anyone recommend somewhere to buy an RCM in UK who will accept returns?
I can fit the unit myself as it is a simple plug & play.
Old May 25, 2020 | 05:30 PM
DTMenace's Avatar
Candyman
The link below is to the Crossfire group in the UK, they should help you with your no start issues and point you to a solution.....
Good Luck,
Dennis
DTMenace
https://www.crossfireforum.org/forum...owners-uk.html
Old May 26, 2020 | 03:48 AM
Candyman's Avatar
Thanks Denis. Looks like we have quite a large UK Crossfire community. I will ask the question there.
Old May 26, 2020 | 06:17 PM
tighed1's Avatar
I get them from all over. This one came in from Spain today. Took 3 weeks to get to me!😳
Old May 26, 2020 | 11:22 PM
Tighed1 is the place to go if you want your RCM repaired! Unless you can do it yourself, go with the flow!
Old May 29, 2020 | 01:17 PM
Candyman's Avatar
Very Happy... I went to the UK group and raised the question on there about my issue. Many owners were also saying that it was a problem with the RCU and pointed me to a UK parts dealer. I ordered the new RCU, which arrived today. As this is plug and play, I was able to fit the part in seconds. I am very happy to say that the old girl started straight away.
Thank you all for your help. Without your help, I expect that I would have ended up with lots of garage bills.
Old Jun 1, 2020 | 03:32 AM
Candyman's Avatar
And here she is. Fixed, cleaned, new wheel badges, and ready to run again
Dnivek
Feb 2, 2018 12:25 PM
mhajek18
Jun 17, 2015 01:35 PM
jtaylortech3
Feb 26, 2013 06:47 PM
jjg
May 31, 2009 06:34 PM
carpen04
May 15, 2009 04:40 PM
