Vehicle Jacking Points
Old Mar 24, 2021 | 03:57 PM
Mikey208's Avatar
Default Vehicle Jacking Points
Hello all. I'm going to do my own oil change and I was wondering if anyone knows of a place in the front center of the car where I can safely place a floor jack. My intentions are to raise the vehicle enough to place jack stands at each wheel.
Old Mar 24, 2021 | 09:31 PM
Default Re: Vehicle Jacking Points
Yes,I use the rear transmission mount point to jacl..
Problem is getting the jack to it.
I first jack up the rear by the differential and place jack stands.
I can then ease the floor jack in from the side to the transmission mount.
Old Mar 25, 2021 | 08:58 AM
Mikey208's Avatar
Thanks! I didn't see that spot. I'm wondering if this could be a place. Maybe not so challenging to get to?
Old Mar 25, 2021 | 08:59 AM
Could be, I'm not sure how much vertical strength it has.
Old Mar 25, 2021 | 11:00 AM
Mikey208's Avatar
I was thinking about maybe putting a short piece of 2x4 on the jack running side to side and trying to lift it there. Once I got it up high enough I would then place the jack stands and let the floor jack down in order to get to the two screws for the plastic plate.
Old Mar 25, 2021 | 12:20 PM
green24u's Avatar
Or you could just get a Top sider oil extractor and never have to crawl under the Crossfire again to do an oil change.
I have the MityVac (MV7201) 8L capacity. Works great!
Old Mar 25, 2021 | 02:18 PM
I vote 'topsider'. Gets nearly ALL the old oil out.
Old Mar 25, 2021 | 03:31 PM
Mikey208's Avatar
Veddddy interesting. Are these expensive?
Old Mar 25, 2021 | 03:54 PM
On the weekend a guy was at a DIY garage when the car dropped from blocks or whatever and was squashed.
I never heard how he fared from his injuries.
Get a topsider capable of holding more than 8 qts. mine holds 10 liters.
Old Mar 25, 2021 | 03:57 PM
There are many sizes and methods to get a vacuum so use Google.
Old Mar 25, 2021 | 04:29 PM
Mikey208's Avatar
Okay. Thank you. I do not wish to be trapped under the car.
Old Mar 25, 2021 | 05:06 PM
The Crossfire is a natural for topsiders because you can also change the oil filter from on top.!
Old Mar 25, 2021 | 06:31 PM
Mikey208's Avatar
I didn't think about that. But, yes, I can see how there's no reason to climb underneath it if you don't have to. I looked around and eventually bought one on Amazon. Thanks for the help! 👍
Romad
Dec 5, 2020 08:23 PM
victorlautreamont
Jun 29, 2017 01:22 AM
ninsei
May 6, 2011 06:23 PM
texas t
Oct 19, 2009 04:57 PM
Joevano
Nov 18, 2005 11:37 AM
