Crank Issues, Shift Issues
Old Aug 18, 2021 | 10:44 PM
Zumbahlenm's Avatar
Default Crank Issues, Shift Issues
Hello,
I have a 04 fire with 28k miles. Ive had it for a few months and I am having some issues. So far I have had to replace the window mirror switch, key ignition and transmission sensor o-ring.
Right now I am having starting issues. The car wont start for the most part. When I go to crank it all the dash lights come on nothing happens. I do not hear the fan. Everything is quiet. However I have tried a few times and sometimes I can get it started. Also the spoiler is up and flashes red light when all lights come on.
It has a check engine light on. P0600A - Serial Communication Link.
If I start it I can drive it....unless all the dash lights come on. Then it will NOT shift out of park. If for some reason I start it and put it in drive and the dash lights come on I can only drive it in 1st Gear.
Is this the RCM?
It was diagnosed at a Chrysler dealer which said it needs a relay and possibly shifter linkage but they dont have the parts. They put on paper 5099007-AA Relay Non 08052328 Sop Bo Pos Local $85 More...is this a fuel relay??
Old Aug 19, 2021 | 08:43 AM
bc75's Avatar
Default Re: Crank Issues, Shift Issues
I would say the rcm. Mine would have trouble starting then when it did start would shift out o 1st. Put new rcm in back to normal.
Old Aug 19, 2021 | 09:57 AM
Zumbahlenm's Avatar
ok are they all the same for the years? or should I pull it and search part number? Can you link me where to buy it?
Old Aug 19, 2021 | 10:06 AM
What did you replace and why in the keyed ignition? Also don't use Chrysler dealers it is a 2004 Mercedes SLK 320. Use an independent shop that works on Mercedes.
Old Aug 19, 2021 | 10:08 AM
tighed1's Avatar
I can refurbish your RCM for about a third of the price of a new one.
Email me at tighed1@hotmail.com for the details.
Old Aug 19, 2021 | 10:16 AM
Zumbahlenm's Avatar
Key was stuck in the cylinder. OK true I will remember that.
Old Aug 19, 2021 | 06:02 PM
Deepsea21's Avatar
Amazon... As others have done, probably best to order this to get you going and then send your existing one to the member here who refurbishes them. Up to you what you decide to run with then be it the refurbished one or the Stand Motor Products one but it's smart to keep a working spare in the car.
Old Aug 20, 2021 | 12:31 AM
philosophico's Avatar
Lawdy RCM's have went up since I last bought a new one. They were $99 bucks a few years ago.
Paulo
Dec 15, 2022 11:40 AM
pneese973
Dec 20, 2018 05:49 PM
Salo
Jul 16, 2018 02:36 PM
king happy
Jul 27, 2017 03:44 PM
autumnmass
Nov 15, 2013 08:09 AM
