Car Alarm Going Off!!!
Old Aug 27, 2005 | 11:26 PM
kev1976's Avatar
Angry Car Alarm Going Off!!!
Last night at about 1 am my alarm starting going off for no reason. After running outside with angry looks from neighbors I shut it off. Then soon after, I was awakened from bed to hear it again, and again. About 6 or 7 times it just went off for no reason. Once with me just looking at it from inside the house, no one was tampering with it. And it was parked on a level ground... the same place it is every night.
I discovered disconnecting the battery will not shut the alarm off, must have a separate source. It was very humid here last night if that has anything to do with it, (and it was very humid a couple weeks ago when the same thing happened).
I finally just left the doors unlocked all night to prevent the alarm from activating again.
Anyone else have this problem? Its driving me and my neighbors nuts!!!
Old Aug 27, 2005 | 11:37 PM
al_luss's Avatar
Default Re: Car Alarm Going Off!!!
Hi Only had it happen one time and the only way it would shut off was to start the car.
Old Aug 28, 2005 | 10:50 AM
kev1976's Avatar
I would get it to shut off, but it would just start up again 15 minutes later or so.
I even made a few trips around the block at about 2 am ... but then soon after I got home and parked it... alarm went off again!
Old Aug 28, 2005 | 06:48 PM
chxf's Avatar
Until you get an appointment for service check, pull the fuse. Good luck and silent nights ...
Old Oct 11, 2005 | 03:08 PM
cfire's Avatar
I had a Toyota Camry that did that once. It was a wiring problem.
Old Oct 11, 2005 | 06:13 PM
65fish's Avatar
Kev, What is the status on your alarm? My new crossfire is supposed to be here tomorrow. I will tell you that after 12 weeks in the shop they still have no idea why my alarm keeps going off. But i have convince Chrysler to do a buy back that's why i am getting a new one.
65fish
Old Nov 25, 2017 | 04:03 PM
Jim Holian's Avatar
chxf - I'm having the same problem as others above. As you suggested, until I can get in to the dealer, I pulled the fuse. I now have to manually lock the car with the key. No big deal! I would prefer to use my key fob remote but the absence of the fuse, I guess, prevents that. I'm a zero when it comes to electrics and computers. Seems like there should be a way to unhook (electrically) the alarm. Anybody have any ideas? I can't even FIND the alarm so, I need help there too.
Thanks, Jim
Old Nov 25, 2017 | 04:39 PM
Thanks, Jim
The siren is under the cowl in front of the windshield, take off the cowl and you will see it to unplug?If you can take off the cowl you might as well remove the alarm and replace it with a new alarm while you are at it. It is plug and play.
Old Nov 25, 2017 | 09:38 PM
Jim Holian's Avatar
Thanks for the information. I will look at the cowling in the morning and see what I can do.
Thanks again,
Old Nov 28, 2017 | 03:34 PM
magredvet's Avatar
In all probabilities the old siren will be toast, which is what is causing it to go off. You can replace it with a Benz siren that beeps when you lock/unlock the car, for about $90. I can get the part number if you need it.
I am assuming this because the car still locks/unlocks with the fob.
If you haven't already, do yourself a favor and remove the plug from the passenger side trunk recess (from below)
Another cause of the alarm going off at random, is the central locking pump being submerged in water, due to a leak into the trunk.
Mine got full of water when I was out of town, sounded the alarm, and flashed the lights for so long that that the battery eventually went flat, locking me out.
Anyway it's piece of mind to check the trunk well for water, and if none present, a change of the siren should be all you need.
Old Nov 28, 2017 | 04:05 PM
Jim Holian's Avatar
magredvet - Thank you for your input. I would appreciate the Mercedes part number for the alarm, if it's convenient for you to find. Did you have to change any of the wiring? If it's a straight swap, with the existing wiring, it sounds perfect for me. I've heard rumors, and that's what they were, that you need a different wiring harness to install the Mercedes alarm.
I looked under the hood the other day and couldn't even see the alarm. On the firewall there is a opening with something red behind the opening, and as best as I can tell, it has the VIN on it.
I've built several street rods in my life, and a couple of race cars as well. The electronics on those vehicles were very simple. This is a new adventure for me. I'm 79 and I refuse to give up! Especially since I keep telling myself that I'm 39 and I can do anything. Well, almost anything.
Thanks again,
Jim
Old Nov 28, 2017 | 04:09 PM
Thanks again,
Here is a PDF giving the part numbers of the beeping siren. CLICK
Here is a PDF with a view of the siren under the cowl. CLICK
Old Nov 28, 2017 | 04:43 PM
Jim Holian's Avatar
onehundred80 - I'm unable to get any of your photo's. You can email me at jpmlholian@aol.com if that is convenient for you. I just can't seem to see the alarm.
Jim
Old Nov 28, 2017 | 05:02 PM
Jim
Click where it says click and a PDF file will open.
The photos are in the PDFs.
mhajek18
Dec 30, 2015 03:40 PM
autumnmass
Jul 2, 2015 10:35 PM
gobraves423
Jun 6, 2015 07:03 PM
Rwright2
Sep 18, 2003 04:55 PM
Iceman
Sep 15, 2003 07:14 PM
