Door Pin Surrounds...
Old Mar 6, 2006 | 01:25 PM
jpristel's Avatar
Default Door Pin Surrounds...
Yeah, I wasted $23 ordering some chrome door pin surrounds off ebay. Now my only question is: How do I get the old (plastic) ones out without damaging the material covering the door panel? They appear to be glued in place.
Thanks
Old Mar 6, 2006 | 01:53 PM
bobs's Avatar
Default Re: Door Pin Surrounds...
Have you contacted the vendor and asked what their recommended procedure is?
Old Mar 6, 2006 | 02:07 PM
jpristel's Avatar
I know on their site and on ebay it says to just pull the old surrounds out and put the new ones in. My only concern is I have one of the first Crossfires produced, and I know Chrysler might be cutting corners to reduce total cost (such as glue . I just wanted to know if anyone else has replaced these and if so, were they glued and did they just yank them out...
Thanks
Old Mar 6, 2006 | 03:16 PM
RowdyRoadster's Avatar
had a thought, yeah I know scary. anyway what if you unlock the door, remove the door pull/pin. then lock the door so you have the open hole. Now bend a stiff wire /coat hanger into a small hook and see if you can stick it into the hole and then pop it out from behind. Maybe even wrap some electrical tape around the wire to keep from scratching up the old surround. Like I said, just a thought.
Old Mar 6, 2006 | 03:41 PM
bobs's Avatar
Thanks
Judging by what they said then, I wouldn't imagine there's a whole lot there holding them in. Probably just press fit. You might even be able to pull them out by wedging your fingernails under the lip and giving a gentle tug.
Old Mar 6, 2006 | 07:18 PM
Cyril Baldwin's Avatar
It's very tight that I have to tear up the plastic door pin surround using pliers! Who needs it anyway once your chrome surrounds are already there?
Old Mar 6, 2006 | 09:02 PM
jpristel's Avatar
Yeah, I tried 5 fingernails at once and nearly ripped them all off. I'm just going to fabricate a small tool to do it or possibly grind down a cheap crescent wrench.
Thanks
Old Mar 6, 2006 | 10:15 PM
Woodlands's Avatar
I can tell you that getting the surrounds out is a piece of cake compared to getting the new ones screwed in. They fit very snug. I had to use pliers to get them screwed into the door. Then I had to sand/polish to try and get the scrape marks off the surrounds after using the pliers on the aluminum.
I would suggest that you use a touch of grease or some sort of lubricant on the surrounds before screwing them into the door. That will likely help a lot. Good luck.
Old Mar 7, 2006 | 02:32 AM
jpristel's Avatar
I wish I would've read this before putting mine in. I was gentle pulling the first plastic one out and it snapped into 2 pieces (one of which fell into the door panel and is staying there until I upgrade the stereo). The other one I just ripped it out and it came out perfect. It looks nice enough to put in a new car. I figured that it'd be difficult getting the new ones in without ruining the finish on them so I wrapped them in a thick rubber band but my pliers still bit through... I'll file them down once it's light outside.
Thanks all
Old Mar 7, 2006 | 10:14 PM
Woodlands's Avatar
Glad to hear that you got the surrounds installed. Good luck getting the plier scrapes out. The job is a pain in the rear.
Old Jun 29, 2008 | 01:05 PM
Violenteer's Avatar
okay. i just did this.
i learnt through trial and error on the first door, and some scratched tint on my wondows, that will have to be repaired.
anyway. imo. best way to tackle it is to actually remove the pins. allows you crush the the plast surround inwards using a set of needle nose pliers. pull. dont be gentle. you ar going to lose it anyway. the plastic surround is going to be a right off.
as for the new surround. my one were not fully threaded. thead ended about 3 mm to the top. so i did see the point in destroying them using pliers to screw them in.
anyway. my way. a piece of felt. a hammer. felt over new chrome surround. tap. tap. bash. goes right in. it has some movement. use a syringe and push some sicaflex in there. problem solved. takes 4 mins. saves the chrome piece from damage.
I also put the chrome door pins in. looks great.
and yes. righty tighty. lefty loosey.
Osusannah
Feb 12, 2024 01:49 PM
Valk
Jul 12, 2021 09:49 PM
Mackel
Oct 16, 2015 09:03 AM
Billy22Bob
Sep 28, 2015 08:08 PM
jaesa
Sep 7, 2015 01:50 PM
