Hot or oil burning smell while driving
Old Feb 13, 2009 | 09:31 AM
  #41 (permalink)
maxcichon's Avatar
Default Re: Hot or oil burning smell while driving
There have been a few oil leaks at both the valve cover gasket and a little cover mounted to the valve cover. In either case, it should be relatively inexpensive.
Old Feb 13, 2009 | 09:38 AM
  #42 (permalink)
speeddiva989's Avatar
does anyone have pics on how to change it yourself??
Old Feb 13, 2009 | 09:40 AM
  #43 (permalink)
does anyone have pics on how to change the valve cover gasket yourself?
Old Feb 19, 2009 | 08:10 AM
  #44 (permalink)
stlas69's Avatar
Sorry mine was done by the dealer, they replaced the entire valve cover.
Mark
Old Feb 19, 2009 | 08:48 AM
  #45 (permalink)
beasticles's Avatar
I have seen that most of you have posted that you had "the smell" of oil or gas leaking during normal driving. However when pushing the car (i.e. revving to 5500rpm and shifting) I do get the burnt oil smell momentarily afterward. I assume this is normal correct? I checked my oil pan guard by removing it and found no leaks. Please let me know as I have always wondered if this is normal.
Old Feb 19, 2009 | 09:06 AM
  #46 (permalink)
Hangman's Avatar
You might be smelling your clutch. I get the clutch smell whenever I drive hard.
Old Feb 20, 2009 | 12:20 PM
  #47 (permalink)
REVIT93RX7's Avatar
I would suspect that any smell of oil, coolant, plastic etc. is not normal. I would continue to search and find the source.
Old Dec 31, 2012 | 10:59 PM
  #48 (permalink)
Erzer's Avatar
Old thread, but good information. I've started to get the smell...at 92k miles with a wrap warranty. Better check to see if it is covered.
Old Jan 5, 2013 | 11:35 AM
  #49 (permalink)
Chris L.'s Avatar
My 08 had the valve cover gaskets redone when it was still under the 3/36 & my 07 had the covers completely replaced under the lifetime powertrain warranty.
Old Jan 5, 2013 | 06:38 PM
  #50 (permalink)
FIXRE's Avatar
How timely! Took my roadster in for an oilchange last week and was told at pick-up that I should have my gaskets replaced due to leakage.
I did notice a slight burt oil smell during the summer but it seemed to go away. In Sept. I made a road trip to middle Tennessee about 1200 mile round trip. Checked oil before leaving home and again before leaving for home and neither time was the oil low on the dip stick.
When I was washing the car after the trip I did notice quite a bit of oily residue in the front wheel well, rocker panel inside the door frames and rear wheel well. I had driven through some rain on the way home and figured I had run through some spillage on the highway. Again checked my oil level and again it seemed okay.
I have absolutely no reason not to trust my machanic. His dad was my machanic since 1965 and I credit him with my getting 250k miles out of my first VW, a second Vw and a BMW. Although my original mechanic has passed away his son has always seemed to be honest a fair.
Does $750.00 seem a little steep to replace the gaskets?
Old Jan 7, 2013 | 08:30 AM
  #51 (permalink)
Abaton6's Avatar
Fixre, Which gaskets? If you mean the valve cover gaskets, $750 is WAY too much.
Old Jan 7, 2013 | 08:43 AM
  #52 (permalink)
RockAuto has a set for around $26
Labor on replacing should not exceed 1 - 2 hours max.
It is really an easy DIY ......
NOTE: The little covers on top of the valve covers do NOT have gaskets, that is RTV sealant. There is a how-to here somewhere on that too .
( you can get a set of stainless steel valve cover bolts for $32.95 from http://www.needswings.com/Valve-Cove...32vcbolts.aspx )
Old Jan 7, 2013 | 01:36 PM
  #53 (permalink)
Chris L.'s Avatar
Both of mine were repaired by the same dealership. On the 08 the gaskets were replaced under the 3/36. On the 07 however, they said there was a TSB from Chrysler to replace the entire valve covers....they said that would have been about a $1,000 if I had had to pay for it.....Thank you Lifetime Powertrain Warranty!!
Mind you......both leaks were so minimal that if I had had to pay for the work.......I wouldn't have had them repaired. Certainly not by a dealership anyway.
Old Jan 8, 2013 | 10:40 AM
  #54 (permalink)
AlG's Avatar
AlG
Back in Sept I had mine replaced under the 8/80 extended warranty. Didn't seem to me like it was that much of a job. When the service writer told me about it, seemed to me like it was more of an afterthought.
Old Jan 8, 2013 | 11:11 AM
  #55 (permalink)
autumnmass's Avatar
I have maxicare extended warranty on my 07 roadster was wondering if this type of problem would be covered. Unfortunately I don't have the lifetime powertrain warranty.
xfClifford
Mar 3, 2021 04:52 PM
PNA
Nov 12, 2020 04:44 PM
Hoppy
Dec 7, 2018 07:36 AM
waldig
Jul 15, 2015 02:05 PM
