Piece of latch for top fell into the top of windshield
Old Apr 7, 2008 | 06:30 PM
Rapps's Avatar
Question Piece of latch for top fell into the top of windshield
Need some help with this. On the dragon we would hear a rattle as if something was rolling around in the front (dash/door/glove box) but didn't find anything. When we put the top down we found that a plastic ramp with push pins (for latch to connect too) had fallen into the metal housing that runs across the top of the windshield. It is rattling and rolling/moving when you turn a corner to the right. I tried to use various things to move it manually to the latch area get it out and also tried to push it with the "force of the shop vac" but no luck. Any suggestions? thanks in advance.
Old Apr 8, 2008 | 02:08 PM
Midwest Muscle's Avatar
Default Re: Piece of latch for top fell into the top of windshield
I think that's the kind of things that happen when you name your cars :-) Okay seriously, I've not heard of that one, but now I have something else I'll need to worry about! I'll keep on eye out for answers from people that know Crossfire's better than I do, which is probably about 99% of this board. Good luck!
Mike
Old Apr 8, 2008 | 05:08 PM
Rapps's Avatar
Mike,
The weird thing is this plastic ramp piece is not very well designed in as much as it fell out on both sides and we didn't even know it was a removable part. Gary realized what had happened (to creat the noise) when the second one popped loose as he opened the top. The bottom of it has those spreadable tab clip things, all plastic and don't they seem to stay spread apart enough to lock into the metal piece below. I'm putting a tweezer in the glove box so if it slides to the latch hole I can snag it. Maybe a little sticky stuff on them before reinstalling them? The names?? not for the car!!
Old Apr 8, 2008 | 05:23 PM
woodlands1's Avatar
Originally Posted by Rapp's yellow CF
Mike,
Maybe you need to get a couple of new ones and see if they would do the job.
Old Apr 9, 2008 | 05:47 AM
Rapps's Avatar
Thanks and it would be a good idea, our main problem now is the one stuck in the hollow bar/beam part of the car that you lock the top down onto. It slides and so makes a rather loud noise, like a marble rolling along- not very pleasing to hear. Hoping someone would know how to get it out, don't want to let the dealer try they will disasemble the whole top of the windshield and it will never be right.
Old May 31, 2008 | 06:23 PM
Rapps's Avatar
On the left is the passenger side showing the piece which fell into the retangle hole. On the right is the drivers side showing the piece still in place. It's still in there we carry around a pair of bent nose tweezers so if it slides to the opening I could snag it. No luck so far.
Old Jun 1, 2008 | 02:19 AM
crossfirefun's Avatar
Can you stick a piece of masking tape in the hole sticky side up and then go fora quick ride? That should stick it to the middle anyway.
Old Jun 1, 2008 | 02:54 AM
yanni2112's Avatar
Can you try a telescoping magnet as well? They come in a variety of sizes and thicknesses. I have two sizes in my toolbox for dropped/missing hardware. It looks like a car antenna with a magnet on the end.
Old Jun 1, 2008 | 10:12 AM
Rapps's Avatar
This is what I like about the forum so much. In our house I usually come up with the ideas, but I'm out of them. You have a good one and I'll try it. Yanni- again a good idea but to get into the hollow beam it must bend (right angle) to travel into it. Also I don't think the piece is metal, not sure.
Old Jun 4, 2008 | 03:05 AM
yanni2112's Avatar
You know what? After reading this thread I went outside and checked ours out, and Ill be damned if 1 side isn't missing too. No noise but what will this cause to happen if not immediately corrected?
Old Jun 4, 2008 | 03:14 AM
Rapps's Avatar
I've got no fracking idea!
Old Nov 21, 2011 | 06:40 PM
Pacemaker's Avatar
Question Re: Piece of latch for top fell into the top of windshield
...so now that I've got a Roadster, I am curious about the outcome of your errant piece. Any lasting effects? Did you replace the missing piece? I noticed that one of those plastic parts at the top of the windshield that hold the top down do not match and suspect a piece of the driver's side part is missing on my car. Any info. would be greatly appreciated.
Thanx,
Jonathan
PACEMAKER
Old Nov 22, 2011 | 06:24 AM
autumnmass's Avatar
Unable to open the pictures, not sure what format they are.
Old Nov 22, 2011 | 07:03 AM
Pacemaker's Avatar
Yeah, they wouldn't open on my MAC either..
Old Nov 22, 2011 | 07:53 AM
[quote=Midwest Muscle]I think that's the kind of things that happen when you name your cars /quote]
Actually, that is the kind of thing that happens when you do not 'cushion' the top when you pull it over center as the last step before latching.
I usually sacrifice a hand to cushion it, but have found that if you are really careful, you can gently pull it over center and catch it before it slams into those 2 latch plates.
Old Nov 22, 2011 | 01:42 PM
Learnin's Avatar
[QUOTE=alaxfire]
I agree...I make a converted effort to ensure the top comes down gently.
Old Nov 22, 2011 | 01:45 PM
Learnin's Avatar
[QUOTE=Learnin]
Concerted, that is.
55chevy
Jul 22, 2024 02:31 PM
Nexxus
May 8, 2016 04:43 PM
smokey847
Nov 12, 2015 11:54 PM
Mackel
Oct 16, 2015 09:03 AM
eatmycrackers
Sep 23, 2015 09:08 AM
