Top not coming down
Old May 23, 2009 | 07:06 AM
DMS Xfire's Avatar
Default Re: Top not coming down
I was wondering if anyone has the wiring diagram or workshop manual pertaining to the top operation they would like to share. There is nothing mentioned in the online 2004 manual about rag tops.
Old May 24, 2009 | 07:33 PM
rayman1946's Avatar
Just thought I would let everyone know I think I fixed my top . It was the sensor on the convertible top frame above the passenger window. It's the one that senses when you push the front of top up after it's been unlatched. If you look up under the top material on the outside above the passenger window ,you will see the switch and a little plastic slider thing that works it. Mine was all pasted up with a white grease of some kind that dried up to a stiff paste. Switch didn't sound good either.Sounded like it had absorbed some of that grease too. Took it off and cleaned soaked in electrical contact cleaner, and put back together, with just a little lube on slider thinge.. and top has worked every time since....... Thanks for everyones help.....
Old May 25, 2009 | 02:11 AM
tdannar's Avatar
It would sure be nice if someone wrote up a list of all the sensors and where they were located and then make a stickey out of it. Would be a lot of help in the future....
xfireohio
Jul 20, 2020 12:03 AM
ZERACER
Jul 7, 2020 10:21 PM
4drturbo
Jan 3, 2019 02:46 PM
Ralph289
Jul 26, 2015 12:52 PM
mike28117
Jul 17, 2015 01:59 PM
