Changing Engine Coolant
Old Jul 11, 2009 | 08:13 PM
tburrey's Avatar
Default Changing Engine Coolant
Since my car is about 5 yrs old now thinking about performing this task. Anyone done this? Any tips on how this is done? I've done it on lots of my previous vehicles but never on a Crossfire.
Old Jul 13, 2009 | 08:07 AM
theglot's Avatar
Default Re: Changing Engine Coolant
I decided last Fall that it was time to change the coolant in my '04.
Found the special antifreeze at NAPA. Make sure you get the type recommended in your manual. You don't want to mix the different types.
Put it up on a lift, unscrewed the drain plug and let it drain for 30 minutes. Opened up one of hte block drain plugs and drained the block.
Put in the new and am good to go for another 5 years.
(Caution if you do this at home. Antifreeze is extremely toxic to pets)
Old Jul 13, 2009 | 08:45 AM
waldig's Avatar
Talking Re: Changing Engine Coolant
Me I use Prestone and it works.
What is IMPORTANT it that you use distilled water. The minerals in water will PLATE out on the radiator and motor leaving nasty HARD deposits that you dont need.
I also use a 10 minute flush thru the engine before I dispose of the antifreeze. Service stations recycle antifreeze FYI.
WOODY
Old Jul 13, 2009 | 09:33 AM
theglot's Avatar
Glad you mentioned distilled water. I forgot to add that point.
My owners manual calls for Zerex and I was able to find it at NAPA.
Old Jul 13, 2009 | 08:12 PM
tburrey's Avatar
Thanks so much for the info. I've used all color Prestone in all my previous sports cars and motorcycles with never any problem with distilled water. Thanks again. Tom
PNA
Nov 12, 2020 04:44 PM
skeet370
May 15, 2018 12:57 PM
rmcdaniel12
Aug 31, 2015 11:53 AM
Ralph289
Jul 26, 2015 12:52 PM
Tp'sfury
Jul 17, 2015 01:15 PM
