Battery
Old Jul 22, 2009 | 11:41 AM
tburrey's Avatar
Default Battery
I purchased my 2005 Roadster a couple of weeks ago and have gotten a great deal of help from this forum which I reallly appreciate. My next concern is that I've noticed the battery in my car is not the right size. The previous owner has replaced it with a much shorter battery and of course I don't know the age of the battery. Can someone advise me on the best and correct size battery with a good price to buy for this car? Thanks in advance.
Old Jul 22, 2009 | 11:48 AM
+fireamx's Avatar
Default Re: Battery
Chances are the "New" battery in your car isn't that old, since the original batterys seem to have an "average" life span of around 4 years.
Lots of performance minded Crossfire owners actually look for a "smaller" or "lighter" battery to replace the original just to make the Crossfire less "nose heavy". (improves handling).
As long as the battery you now have starts the car everytime, and holds a good charge, I wouldn't change it.
Old Jul 22, 2009 | 11:50 AM
Default Re: Battery
you can go to any auto store ,,sears napa any one can tell you the correct size of the factory Batt.. I have beeb doing a test with a small batt, 400cca and for a month now it is working great it weights 12 lbs the stock batt weights 40 + lbs, and is 690 cca. the size is so it fits in the space and can be bolted down, see this .------------ https://www.crossfireforum.org/forum...tery-test.html ------- jim
Old Jul 22, 2009 | 11:55 AM
tburrey's Avatar
Default Re: Battery
Thanks for the tip on the battery Fireamx. I'll keep that in mind. Happy driving and thanks for the quick response.
Old Jul 22, 2009 | 12:01 PM
tburrey's Avatar
Default Re: Battery
Thanks Jim for the battery test info very helpful. Tom
Old Jul 22, 2009 | 08:45 PM
Default Re: Battery
click here >>> Battery Replacement - Interstate MTP-91
Old Jul 22, 2009 | 09:31 PM
The Beep's Avatar
Default Re: Battery
The battery in my 05 fried over the winter. I jumped it and drove to "Batteries Plus" and they installed a new one for under $100. Works great. Not sure if Batteries Plus is nationwide.
Old Jul 22, 2009 | 09:55 PM
bsb6's Avatar
Default Re: Battery
My car failed to start Saturday night while out for dinner, wouldn't jump. So I ran to Advanced Auto. Lucky me, they would have to order it, only $149.00! I went back to pull it out and charge it overnight, tried once more to jump and it started up. Everything looked clean, no visible problems, when I pulled off the positive cable it looked a little dirty, that was the problem. I did notice some special top with what looks like some small vents, which is what makes them so expensive, according to Advanced Auto.
Old Jul 22, 2009 | 10:43 PM
Default Re: Battery
Interstate all the way!
James
Old Jul 23, 2009 | 05:29 AM
crossfirefun's Avatar
Default Re: Battery
There should be a label on the top of the battery that is punched out to tell you the year it was sold or the year it's factory warranty expires. If the latter just subtract from the year. This will at least give you a ballpark age.
blackpepper
Oct 4, 2017 06:09 AM
Reliableron
Oct 17, 2015 10:19 PM
o55ie18
Oct 5, 2015 05:50 PM
rmcdaniel12
Sep 22, 2015 01:20 PM
Valk
Sep 17, 2015 11:43 AM
