Steering stabilizer-what does it do?
Old Aug 5, 2009 | 04:43 PM
Tommy Canuck's Avatar
Default Steering stabilizer-what does it do?
Took my 2005 in for an oil change. Get a call saying the "steering stabilizer" is leaking a very small amount and should be replaced? OK, no big deal, let's replace it. I ask how much? He says. for most cars about $50, but I will check and call you back. Calls back and tells me that a steering stabilizer for a Crossfire is $850, plus the labour to install it!! I was thrown back and said what will this do for me.He says not much, you might not even notice the difference because it does not hold that much oil anyway, so you might not even notice any difference.
Give me your opinion, if I really have to do this, I will do it, pay the money and shut up but this really feels like a monumental amount to pay for this part.
Thoughts?
Tommy
Old Aug 5, 2009 | 04:48 PM
nate_man's Avatar
Default Re: Steering stabilizer-what does it do?
Thoughts?
Tommy
Tommy a couple of things:
1. The Sterring stabilizer helps reduce the pull on the steering wheel as you drive on uneven and grooved roadways.
2. Although yours may be leaking it does not mean that it is junk or gone but it likely is less effective.
3. The dealer is quoting a real price (yes very inflated but real). I just had mine replaced under warranty and they wanted $650 for the part alone. I saw the actual dealer cost and what it was to me and the difference was only $100 bucks.
4. THe most important part, you can save a ton by buying one on amazon (do a search on the site) and if you are even a bit of a wrench it is a two bolt deal and you are back in business.
Trust me after I had mine done (car only has 19k) I noticed a big difference and it too was a leaker.
Hope this helps.
Try it you may like it!
Nate
Old Aug 5, 2009 | 05:12 PM
OKC-XFR's Avatar
I got mine here for $20 + $9 shipping:
Steering Dampner Mercedes Benz SLK 230 320 32 AMG W170 - JoeTLC
It was all of 15 minutes to change.
Old Aug 5, 2009 | 06:43 PM
laitsabr's Avatar
Here is a thread with even more info and shared experience:
https://www.crossfireforum.org/forum...surprised.html
Old Aug 5, 2009 | 07:14 PM
Lark's Avatar
Ordered one just now without looking at mine. For the $30.00 it's worth having it on hand........
Art Rigsby
Old Aug 5, 2009 | 07:26 PM
I got mine for $29/delivered as well. Took a whole 15 minutes, start to finish.
James
Old Aug 5, 2009 | 09:54 PM
Thank You very Much,
Here is what I do not understand. Why would Chrysler charge that kind of money for a $30 part? I mean, even at $100 plus labour I am the kind that says.."just do it", but at that kind of money I had to go to the forum and get some opinions,and am I glad I did. I will order the stabilizer and do it myself. Question,do I only need 1 stabilizer or does it take one for each side of the car?
Told you I was stupid
Tommy
Old Aug 5, 2009 | 10:38 PM
Just one Tommy boy, and you will be glad you replaced it, the $850 one is a pos....LOL>>>>>
Old Nov 29, 2010 | 07:56 PM
clarkandrew45's Avatar
Banned
Thoughts?
Tommy
Hello there tomy, the same thing happened to me last month and the only advice that the mechanic tool me is to replaced the whole stabilizer. That was quite expensive but the leaking will still occur if i will not replaced that.
Old Nov 29, 2010 | 07:58 PM
Larry Hitze's Avatar
Take the forum's advice, do it yourself if you can. Very Easy
Old Nov 29, 2010 | 08:05 PM
green-ghost's Avatar
Cheep and very easy for sure. The hardest part is removing the bottom splash shield but an extra pair of hands helps. Seriously, if you can change a tire, fuse, or motor oil; you can do this replacement
Old Nov 29, 2010 | 08:08 PM
KrzyFast's Avatar
If you really aren't into working on your car, still buy the part online for $30. Then go find a reputable independent shop and pay them $30-$50 to install it. A 4x4 shop would be perfect as they install these things all the time. It truly is 2 bolts and 15 minutes of your time, if you have the tools to do it.
I can't believe that the dealership wanted $850 for it though?!? Most of the parts for this car are marked WAY up at the Chrysler dealerships, but this seems excessive even for them. Wow!
Good luck.
KrzyFast
Old Nov 29, 2010 | 08:12 PM
bri3d's Avatar
I have all of the splash shields listed in the service manual (the big one under the engine bay that needs to be removed to change the oil, and the forward one under the front bumper although mine is a bit beat up) and I didn't need to remove anything to replace the steering stabilizer. It was behind the engine bay splash shield.
The service manual seems to back me up on this - instructions are just "unbolt and bolt the new one in."
If you've got really long arms and are skinny you don't even need to jack up the car, although I'd do it for convenience. Two bolts, a few taps on each end, and you're done - it's a trivial job.
Old Nov 30, 2010 | 01:41 AM
muskrat's Avatar
Got mine done while they were balancing the wheels - for free Damper cost about £20 and made no difference whatsoever Oh well at least it was cheap
Old Nov 30, 2010 | 07:25 PM
that was last year fellas....wonder how he made out?......LOL>>>>>
deerhunter
Jan 16, 2021 10:56 AM
cdcrone123
Sep 20, 2015 10:02 PM
bbsrt6
Sep 19, 2015 11:21 AM
princepenson
Jul 29, 2015 07:44 AM
Blackout317
Jul 7, 2015 08:38 PM
