Yea, I'm torched
Old May 11, 2010 | 11:11 PM
Learnin's Avatar
Default Yea, I'm torched
I've had my XF for about three weeks now. I checked the oil with the dip stick first day I had it and it looked like it was over max but, since the dip stick is a little different, I thought it was probably okay since the electronic reading signaled OK. I was changing my air filters out two days ago and noticed some oil residue around the valve covers on the left side of the block. I noticed just a little fresh oil sitting in one of the bolts.
I decided I'd better drain some oil out so I jacked it up and noticed that the protective cover was loose. Chrysler dealership must've lost the nut clip and just decided to leave it hang (previous owner was a lady, I'm assuming she took it to the dealer).
I had to drain out over a quart before I could get the level to move down below max.
Do you think I need to be concerned considering the oil film around the cover or is this normal?
Either way, I'm fuming about the utter carelessness of whomever serviced the vehicle. Lady probably paid good money for an oil change....
Old May 11, 2010 | 11:33 PM
MikeR's Avatar
Default Re: Yea, I'm torched
The small cover on top of the valve covers are notorius for developing a leak... they are sealed with an RTV type gasket. If that is where your leak is coming from it is an easy DIY fix and normal....
Old May 11, 2010 | 11:38 PM
Learnin's Avatar
Thanks MikeR. Are you talking about that small compartment that is bolted to the valve cover? I noticed it had a black gasket sticking out that was breaking apart. I do believe that may be where the seepage is occuring.
Old May 12, 2010 | 07:28 AM
hcarter's Avatar
That would be the spot , probably what you see breaking apart is the RTV going bad,,, like mikeR said ,,easy fix. diy
Old May 12, 2010 | 08:22 AM
Learnin's Avatar
Thanks. I suppose you can pick these up at auto store?
Old May 12, 2010 | 06:04 PM
Goldwing's Avatar
Try gently torquing down all the bolts first. Then clean the area and watch for new leaks.
Old May 12, 2010 | 06:21 PM
MikeR's Avatar
and yes, you can buy the RTV at the parts store... there are a few threads on this and how-to...
Old May 12, 2010 | 07:09 PM
Learnin's Avatar
I wondered about that. Looks like it takes a special socket?
Old May 12, 2010 | 07:10 PM
Learnin's Avatar
Thanks. If the light torquing doesn't stop it, I'll get me one and give er a try...
fastfred
Mar 20, 2017 03:11 PM
rmcdaniel12
Nov 4, 2015 04:08 PM
waldig
Aug 5, 2015 02:29 PM
pizzaguy
Nov 14, 2009 11:49 PM
X-FIREcmv
Feb 6, 2008 07:40 PM
