Bad Factory Amp
Old May 24, 2012 | 04:31 PM
cybergeek's Avatar
Default Bad Factory Amp
I am in need of a replacement factory amp. I have been told that its a mess to replace with an aftermarket amp? The factory amp is (model: A1938200489 36670C). I took apart the amp and I don't see anything burnt or blown capacitors, but it isn't working. Anyone know anywhere to pick one up or any other alternative ideas?
Old May 24, 2012 | 04:35 PM
Default Re: Bad Factory Amp
MrMopar's Crossfire shop.
PS I'm working on commission here. LOL
Old May 24, 2012 | 08:11 PM
May seem silly to ask but are you sure there is power to the amp? I have never seen one of these go in the perusing of the forums. BTW, this is free advice!
Old May 27, 2012 | 05:16 PM
cybergeek's Avatar
The amp is bad for sure. I tested the radio and speakers. I checked with several sources and they recommend putting in all new 4ohm speakers and everyones quote comes to around $750 with installation included. I am just wondering if anyone has just wired to a aftermarket stereo? I also have an amp that will fit in the factory location that is two channel and I thought i could combine the dual voice coil 6.5's and power them with it. I would power factory tweeters and mids with the new radio.
I am not an audio nut in anyway just been researching the forum for the best answer to my problem. If you had a bad amp how would you solve it?
Thanks,
-Andy
Old May 27, 2012 | 07:32 PM
MoparFreak69's Avatar
When my amp takes a crap im going to replace it with something better. I will probably do something similar to what you have planned, deck powering vocals and small amp pushing the stock subs, then replace the subs later on with something better.
Old May 28, 2012 | 06:38 AM
MrMoPar's Avatar
Not sure if it was you, but replied to someone yesterday that I have factory amp, but am on vacation, will try to provide info as soon as I can.
syfi
Mar 28, 2026 04:14 PM
steps
Oct 13, 2015 06:18 PM
o55ie18
Oct 5, 2015 05:50 PM
Oct 1, 2015 01:42 AM
mobilefitt
Sep 24, 2015 01:04 PM
