Any way to disable the 9-mph limit on closing the top?
Old Jul 12, 2013 | 11:18 PM
splintergrain's Avatar
Default Any way to disable the 9-mph limit on closing the top?
It is really annoying in parking lots. I do not plan on raising the top at any great speed, I just want to be able to go a little faster than it allows. I understand why it exists and the safety concerns.
Old Jul 13, 2013 | 05:50 AM
Default Re: Any way to disable the 9-mph limit on closing the top?
Do you have the "one touch top switch" upgrade ?
I find that I can get in, start the car, press the switch and then by the time I fasten the seat belt and put on my glasses, it's time to latch the top and go.
Sometimes I even get the car in gear with the brakes on, but I prefer to use both hands on the latching, so never actually move.
( You still have the double-tap both windows up / down feature with the mod )
Old Jul 14, 2013 | 11:59 PM
The 9 pmh speed limit is programmed either in the Top Module, the Body Control Module or the Power Train Control Module - not sure which (they all talk to one another over the CAN bus, who knows WHERE it is!) If there was a way to disable or raise it, I'd sure have paid to have it done.
I'd bet ya it's in the BCM - I know the TCM and BCM talk a lot, 'cause the BCM controls the windows and they are commanded up and down by the TCM, also, the trunk lock position sensor reports to the BCM as well.
Old Jul 15, 2013 | 12:20 PM
I do not have that upgrade. Might have to look into that. I generally have no issue when putting it down, but when I pull into a parking spot, I'd like to have the top already in the process of closing.
ZERACER
Jul 7, 2020 10:21 PM
Hoppy
Dec 7, 2018 07:36 AM
PimpDaddy
Sep 29, 2016 11:55 PM
Ralph289
Jul 26, 2015 12:52 PM
mike28117
Jul 17, 2015 01:59 PM
