So it finally happend...
Old Aug 14, 2013 | 04:48 AM
GTR DRAGON's Avatar
Default So it finally happend...
After leaving work the ignition wouldn't turn, finally after 10-15 minutes of turning the key (and breaking it). The ignition finally turned over. Thank goodness, I was able to get the car home a pull up the sticky key PDF on my phone (DO NOT REMOVE YOUR KEY FROM THE IGNITION, if you can get it to turn ).
It may seem like a lot of steps, but literally of the project 80% is taking apart the dash.
The mechanical bits are a little tricky, but if you use a wire to push in the "little pin" part you can easily remove the ignition
Also don't get confused the little pin part isn't the issue, the part inside the little metal hatch, that you have use a hammer and pointed object to open, is the issue. Just take that part out, with the spring.
The whole process took an hour, the pdf should have mentioned you will spend more time arguing with your sibling, parent, uncle,and /or significant other about the project then actually completing it.
I was one of the ones that thought silicone spray and graphite would fix the issue, and truly it did for awhile, but trust me when I say this... and I hate the be the bearer of bad news, but complete this mod this ASAP or risk getting stranded.
Old Aug 14, 2013 | 08:38 AM
rayth's Avatar
Default Re: So it finally happend...
I've been putting it off for a while myself.. with my luck recently I wouldn't be surprised if it locked up tonight on me..
Old Aug 14, 2013 | 09:26 AM
STEPHENJXN's Avatar
This is definately on my radar
Old Aug 14, 2013 | 11:03 AM
S. Artee's Avatar
Link to referenced PDF, please?
Old Aug 14, 2013 | 11:06 AM
Mrmiata's Avatar
https://www.crossfireforum.org/forum/...key-fix_v2.pdf
https://www.crossfireforum.org/forum...n-key-fix.html
Old Aug 14, 2013 | 11:11 AM
S. Artee's Avatar
Awesome. Thanks Mr. M.
Old Aug 14, 2013 | 11:15 AM
Mrmiata's Avatar
Not a problem.. wanting to get this done BEFORE CAA#4 myself..figure it's time to print and do.. LOL.
Cause we know what's going to happen if I don't..
Old Aug 14, 2013 | 04:11 PM
meh03's Avatar
Do most get a warning by having to try and turn it a few times before it won't work completely? If so, I'll wait until that happens, if not....guess another chore.
BTW great write up!
Old Aug 14, 2013 | 04:14 PM
Mrmiata's Avatar
Mines been warning me for two years.. LOL. (Sticky 95% of the time)
One of these days it will be game over..
Old Aug 14, 2013 | 06:55 PM
Never put off until tomorrow what you can put off until day after tomorrow .....
Old Aug 14, 2013 | 07:14 PM
Mrmiata's Avatar
When it locks up it will move to the top of the to-do list..
Na actually I'm looking to get-er-done Saturday evening..
TerryR
Dec 13, 2019 03:27 PM
aerobluehal1
Canada
19
Oct 13, 2018 09:47 AM
o55ie18
Oct 5, 2015 05:50 PM
Selbyl
Sep 22, 2015 10:41 PM
tritongreen
Sep 18, 2015 07:32 AM
