Convertible trunk
Old Jul 19, 2016 | 08:42 PM
Ben-Hur's Avatar
Default Convertible trunk
Hi folk,
Someboby know what's the function of the huge rectangual storage in the bottom of the convertible trunk (RIGHT side under the flat cover) ?
Old Jul 19, 2016 | 08:52 PM
Default Re: Convertible trunk
Tool storage, in there I have:
A spare crank position sensor
Tire 'worm' plug kit
flat blade screwdriver
#2 phillips screwdriver
adjustable wrench
1/4" drive metric socket set
... a few "star" bits
spare bulbs (corner, headlight, tail/stop/turn)
Roll of Duct tape
Roll of electrical tape
wire strippers
wire crimpers
assortment of electrical lugs/terminals
It also serves as a "leak detector", if you find water in there, you know you are close to flooding the fender wells and seeing the end of your top module and security system module/lock pump.
Old Jul 19, 2016 | 11:25 PM
Steve Jr's Avatar
"Don't worry , I've got duct tape"
Old Jul 20, 2016 | 07:02 AM
adjustable wrench
Roll of Duct tape
wire strippers
wire crimpers
Some use it to carry guns and ammo, here in Canada we carry booze and snow chains.
Old Jul 20, 2016 | 07:05 AM
Back when I got the car 5 years ago, I put a spare quart of Mobil1 0-40 in here, thinking I might need it while on the road.
It's still there, this MB engine uses NO oil between changes.
Old Jul 20, 2016 | 10:47 AM
If duct tape was good enough to save the APollo 13 three, it's good enough for me.
Old Jul 20, 2016 | 01:12 PM
Steve Jr's Avatar
"If you can't fix it with duct tape, you're not using enough!"
Old Jul 20, 2016 | 05:47 PM
Ben-Hur's Avatar
Hello guys... pretty funny to read you but I mean : does the hole was build there by chrysler for a specific application !
Old Jul 20, 2016 | 06:03 PM
No particular use as far as I know.
The bottom of the trunk consists of two wells, the left side well is filled with the tire air pump, tire goo etc. all fitted in a foam block. The right hand well has the security pump in its foam case under another foam block, as the pump does not take up all the well space a pocket is formed in the main block thereby saving foam and providing a storage space.
Old Jul 20, 2016 | 09:21 PM
The specific application, was to save $ on Styrofoam (or whatever that thing is made of). Simple economics for a car company struggling with low quality and high prices.
Old Sep 18, 2016 | 07:27 PM
Ben-Hur's Avatar
I think it was a space for CD changer !
Old Sep 18, 2016 | 08:00 PM
If it was, it is a good thing not too many were equipped, given how many lower trunk cavities are flooding.
Old Sep 18, 2016 | 08:31 PM
You would be in error there, I had a CD changer and it did not fit in the coupe foam pocket as it stuck up a bit.
Old Oct 28, 2016 | 03:00 PM
Goldwing's Avatar
This is a fun game every few years when it re-surfaces. I always go with the bottle of Jack Daniels answer.
Scade
Oct 18, 2016 02:03 AM
McSquiggles
Jul 20, 2016 02:52 PM
Avalon
Jul 9, 2016 07:55 AM
maznonno
Jul 7, 2016 12:24 PM
hcloseuk
Jul 2, 2016 10:37 AM
