Bad SKREEM module?
Old Apr 16, 2018 | 04:53 PM
captaindcd5's Avatar
Default Bad SKREEM module?
So my wife went to start her 2007 Crossfire this morning and it
- cranked, runs a split second, then stalled, after 2 times nothing.
- Also, her Keyless entry does nothing
Everything worked fine the other day.
I checked the battery voltage, cleaned the battery posts, and pulled the RCM and resoldered everything on the board.
Still will not stay running.
I disconnect the ground and reconnect and get the same, cranks 2x then nothing.
she replaced the batteries in the keyfob, and still no keyless entry.
So does this appear to be a bad SKREEM module?
Old Apr 16, 2018 | 05:20 PM
Default Re: Bad SKREEM module?
10 out of 10 chances it is the SKREEM.
Old Apr 17, 2018 | 10:40 AM
NeedsWings's Avatar
if you have tried with your spare key and get the same results, then yes bad SKREEM
jpeez20
Aug 1, 2016 09:35 PM
C9ndl86
U.K.
Jul 31, 2013 09:43 AM
britishcommando
Apr 11, 2013 10:17 AM
britishcommando
Feb 2, 2012 04:51 PM
britishcommando
Jan 7, 2012 04:26 AM
