Trunk latch release
Old Oct 29, 2018 | 04:37 PM
Default Trunk latch release
I have never had the issue but some have had to go through the side marker light to release their trunk latch when it wouldn't open. I have wondered how to actually grab onto it with a wire coat hanger, as suggested, to open the trunk. Trying to be proactive I ties a string loop to the handle to have something to grab. It doesn't stand out and it seems like a simple inexpensive solution. JUST IN CASE
Old Oct 29, 2018 | 06:28 PM
Default Re: Trunk latch release
Would'nt it be a better idea to tie a string to the handle and tie the other end to the wire connector of the license plate light? That way when you took out the license plate light you would have the string at hand with no need to fumble around in the dark for the loop.
Old Oct 29, 2018 | 10:20 PM
turbomar's Avatar
I recall using my skinny roof wrench to flip the roof bow open and then reach in to pull the emergency release on someone's roadster
Old Oct 30, 2018 | 10:53 AM
If you ran a string ahead of time, it might help make it easier but the string might get in the way, in the trunk. Hopefully I will never need it but this was a just in case.
Old Oct 30, 2018 | 11:27 AM
The string would disappear under the trim panel at the end of the pull handle. I am not talking of a few feet of string in the trunk area.
Old Oct 30, 2018 | 02:36 PM
ambidextrous's Avatar
It depends on where the problem is. If the pneumatic lock/unlock isn't working, the emergency release won't work either.
Old Oct 30, 2018 | 03:30 PM
That would be a design that had not been thought out properly, an emergency release must work at all times and that includes when the ignition is OFF.
The release must work at all times, period.
Police officer to a kidnap victim “ Why did you not pull the emergency release?”, “ I tried but the ignition was OFF”.
Old Oct 30, 2018 | 04:48 PM
I agree, Dave, if nothing has failed, the emergency release will "always" work; but if you read pos t#44 in the epic thread titled, "Trunk lid jammed", you'll see a situation where the emergency release won't work - at least that's my understanding of the post.
Old Jan 1, 2019 | 07:18 PM
Goldwing's Avatar
My mind may be going, but I am pretty sure that the only time my trunk refused to open I raised the top 1/2 way and then reached in and pulled the release.
Old Jan 1, 2019 | 09:01 PM
That may have happened, sir, and I respect your superior knowledge of Crossfire lore. If so, you were lucky; It's my understanding that the electrical deck lid lock is enabled by the electrical deck lid latch during top raising and lowering, to ensure the tonneau and deck lid will not collide. The best approach is to use the J hook, via the left license light aperture to open the deck lid; that works, if the emergency release mechanism has not (easily) been broken by excessive force when attempting to open the deck lid when the electrical lock prevents that. If that's the situation, all is not lost, and I have a routine that will open the deck lid, free to anyone that wants it (and also believes what I have said in this post).
Old Aug 26, 2025 | 09:13 PM
ctblackburn's Avatar
I have a 2004 Crossfire coupe, and the latch is broken and I think someone has broken the pull cord or something inside the latch. I’m desperate to get it open and would love and appreciate any help to get in it
Old Aug 26, 2025 | 09:24 PM
Hi,
it looks like you've just joined. Welcome to the forum!
Here's a link that talks about your problem: LINK _ Coupe hatch locked
I suggest that you read the whole thread to get a better understanding of what he's talking about. LINK - Coupe lift gate failure
It only takes a little bit of searching, using the box in the upper right corner to find any answers that you need.
Good luck!
Old Aug 30, 2025 | 10:59 AM
Goldwing's Avatar
The emergency trunk release is a mechanical release. It should always work.
But....the handle pulled off the cable in my roadster. If I get trapped inside the trunk, I have bigger problems than this. However, I am wondering if anybody has any ideas how to work around the detached handle??
HiFiBri
Aug 22, 2017 07:58 PM
Jacksung
Nov 6, 2013 05:06 PM
sissylovescars
May 8, 2013 01:50 PM
molco
Aug 15, 2006 03:18 PM
jbravo8
May 4, 2005 08:51 PM
