Starts but won't run?
Old Mar 13, 2019 | 02:39 PM
tmoore's Avatar
Default Starts but won't run?
Had battery to short out now car won't stay running. Will crank and run for a few seconds then stops. Will crank back up and does the same thing again. It will not crank the third time with out taking battery cable off to reset. Any suggestions?
Old Mar 13, 2019 | 03:09 PM
Default Re: Starts but won't run?
Yes, classic bad SKREEM symptomsd
Old Mar 13, 2019 | 08:41 PM
Yup certainly sounds like a failed SKREEM module
NeedsWings Performance Products. Crossfire SKREEM and Antenna Ring
Old Apr 4, 2019 | 03:18 AM
xodus52's Avatar
I'm currently having the same issue for exactly the same reason. Battery drained out and now the SKREEM-related issues are persisting despite battery swap and troubleshooting. It's extremely frustrating that something as simple as a battery drain could permanently brick the module, it can't be bypassed, and a new one can't be acquired because FCA hasn't been filling orders for them since 2/18/19.
Old Apr 4, 2019 | 02:14 PM
L. Morgan's Avatar
My 2007 Crossfire is sitting in a shop in Irvine and my mechanic is charging me $25 a day while I am waiting for a Skreem modual from Chrysler and Needswings. I paid the $700 over two weeks ago and I guess Chrysler is slow on the backorder. Are we being held hostage by the factory?
Old May 20, 2019 | 02:30 PM
L. Morgan's Avatar
I installed the new SKREEM and I'm back on the road
Old Jun 8, 2019 | 04:53 PM
tmoore's Avatar
I received my skreem from NEEDSWINGS and didn't help. Would not accept my key, lock or unlock doors. Tried to reprogram key but nothing works. Sent to Crown Chrysler to check and they said it needed key, key fob and several other things but didn't send me a needed parts list. Said to come get it because they said parts are out of stock and didn't know when they would be available. I put my old skreem back in and door lock and unlock but still cranks and goes dead. Out 700 dollars and back to start line. Just frustrated I guess. Also had a mercedes mechanic check it and he said his computer will not talk to it.
I must have more than a skreem problem.
Old Jun 8, 2019 | 05:56 PM
maggy55's Avatar
The lock unlock part of your fob is separate from the ignition part. There is a small chip inside the fob that communicates with the skreem . If that chip is missing the car won't start. Make sure the chip is in your fob and that the wire from the ring around your ignition is plugged into the skreem. Needs wings also sells the key fobs with chip specific to your vin number
PNA
Mar 11, 2018 05:43 PM
Joshuastathis
Sep 4, 2017 01:56 PM
pjs626
Dec 6, 2016 07:35 AM
rdooley79
Nov 25, 2014 10:34 PM
KnFleig
Nov 15, 2010 10:15 PM
