mechanic needed in Holland Michigan.
Old Jun 10, 2020 | 12:20 PM
ramarhanka's Avatar
Default mechanic needed in Holland Michigan.
I'm looking for a mechanic in the Holland Michigan area who can work on my roadster I just purchased. The top will not go down. previous owner had it looked at before i picked it up. The mechanic said all the switches are working. He thought that the power lead to the motor was broken?
Old Jun 10, 2020 | 07:42 PM
Default Re: mechanic needed in Holland Michigan.
So the "Mechanic" tore the trim from the trunk and measured the voltages at the PTCM and verified that 'all' switches are behaving as they should?
I somehow doubt this.
If he measured all the voltages on the wires from the switches, why didn't he measure and verify power to the module?
THAT is the EASIEST thing to measure - battery voltage should be on pin 10 of C1 at ALL times.
You don't need a "mechanic", you need someone who understands basic electricity/electronics. And you will SELDOM find anyone at a garage to fit THAT description.
So, let's start with the fundamental question:
If you put the top down manually, will the top go up? If so, this tells us it's 99% certain to be the divider or top open switch.
Manual top operation is discussed here (The manual only tells you how to put the top up enough to limp to a dealer - no dealer can help you):
Old Jun 11, 2020 | 08:04 AM
ramarhanka's Avatar
Thanks for the info, and the video you made will be helpful as I'm going to try putting the top down today. I'm not very trusting of "mechanics" but just don't want to tear into it yet. Just got it home Monday so still just enjoying it, even with the top up.
Old Jun 12, 2020 | 02:54 PM
DTMenace's Avatar
Ramarhanka
The link below contains several repair shops in your area, you may want to give each a call....
Regards and Good Luck,
Dennis
DTMenace
https://www.google.com/search?sxsrf=...sclient=psy-ab
Old Jun 20, 2020 | 12:38 PM
Goldwing's Avatar
I also live in Holland and have used Jason at Intune Imports 616-392-4156 for years for my Audis and Crossfires. So far it has purely been mechanical work, no top issues. I'd be glad to get together with you and compare top operations and ensure you have the partition in the rear set correctly. Email me at jjaiven@gmail.com .
Old Jun 22, 2020 | 09:41 PM
KDW4Him's Avatar
Verhage Motors Of Holland used to be a Chrysler dealer and last I heard, 4 years ago, they had a Crossfire convertible top savvy mechanic there. I don't have experience with them myself just the posting here somewhere.
Old Jun 23, 2020 | 08:08 PM
ramarhanka's Avatar
Thank you. I'll check them out.
msgump
Midwest Forum
Sep 9, 2010 12:49 PM
Big Al
Midwest Forum
Aug 20, 2010 11:34 AM
lifeistiming
Aug 17, 2010 07:31 PM
Sharonaln67
Other Cars Etc
Mar 23, 2007 10:25 PM
Sharonaln67
Other Cars Etc
Nov 9, 2006 10:56 AM
