Dumb question...
Old Jul 21, 2005 | 08:29 PM
gibsonjunkie's Avatar
Default Dumb question...
My Mustang had a manually adjusted clutch that needed re-adjusting about every three thousand miles. I assume the Crossfire is hydraulic and self-adjusting. Is there any clutch adjustment necessary, and if so, how?
Old Jul 21, 2005 | 08:47 PM
chxf's Avatar
Default Re: Dumb question...
The manual transmission is equipped with a conventional dry clutch with automatic wear adjuster.
Hope this helps.
Greets
Old Aug 15, 2005 | 09:57 AM
kwiktsi's Avatar
Umm, the clutch is hydraulically "actuated"- I think that's what he meant by "hydraulic". Mustangs (assuming fox platforms here- can't remember 95-) have cable clutches. They are self adjusting, however you can get a bit more throw on them if you adjusted them yourself from time to time. Hydraulic clutches are self adjusting just like brakes would be since any wear in the friction material will be compensated for with more fluid filling the lines.
Joe
Edit- I know this is late to the game, but I just saw it and wanted to clarify for others who may read it.
psuperti
Aug 30, 2015 12:08 PM
chturner
Aug 23, 2015 06:14 PM
Stogey
Apr 5, 2008 10:18 AM
Maxwell
Oct 30, 2007 08:49 PM
joeyjrfl
Jun 12, 2007 08:57 AM
