Issue with flaps - Help !!!!
Old Apr 14, 2021 | 03:59 AM
danao91's Avatar
Default Issue with flaps - Help !!!!
Hi guys,
I need your help with my crossfire roadster, the flaps should move up and down but they don't. The stay down.
I checked the cable and they seem ok.
I guess the cables need to be tightened ? But where ?
Thanks you so much
Old Apr 14, 2021 | 11:52 AM
danao91's Avatar
Default Re: Issue with flaps - Help !!!!
Hi Guys,
Just to be clear on my previous post :
- When I close the roof, the flaps move down and everything is ok
- When I open the roof, the flaps stay down and I need to move them up manually.
What do you think ?
Thanks
Old Apr 14, 2021 | 06:06 PM
Those flaps move due to the mechanism at the far end of the cables. If they are not operating correctly, the issue has to be at the far end.
But I have never heard of BOTH failing at the same time, often ONE flap fails when the cable becomes disconnected at the far end (not the flap end).
Old Apr 15, 2021 | 07:32 AM
danao91's Avatar
Thanks Pizzaguy,
I checked and you're right the issue is at the far end (not the flap end).
When I open the roof, the cable should go up in the sheath in order to move up the flap. Instead of that, the cable remains soft.
As you can see on the picture. What do you think ?
What would you do ?
Thanks
Old Apr 15, 2021 | 04:44 PM
I would get one of those bicycle cable oilers and see if I could get some good cable lubricant in there.
Old Apr 16, 2021 | 01:45 AM
danao91's Avatar
Thanks you so much.
Old Apr 18, 2021 | 06:09 AM
danao91's Avatar
Hello,
I would like to remove the cable in order to coil it up and soak it overnight in WD40, but I don't know how ?
Can you help me ?
Regards,
jjames
Southeast Forum
Mar 12, 2024 04:56 PM
WindRestrictor
Sep 19, 2014 03:52 PM
aleks
Jan 17, 2013 06:46 AM
Cali_Boy_4_Ever
West Forum
Oct 29, 2009 02:57 PM
amx1397
Jan 11, 2009 06:58 PM
