2005 SRT6 Dyno Test
Old Aug 10, 2006 | 11:26 AM
ichon's Avatar
Default 2005 SRT6 Dyno Test
Here's my dyno results from 08/08/2006. Prepping the XF for upgrades. Target is 400 bhp to the wheel. Will keep you posted.
Old Aug 10, 2006 | 04:07 PM
feets's Avatar
Default Re: 2005 SRT6 Dyno Test
How did you get it to run over 5,000 rpm?
Old Aug 11, 2006 | 11:04 AM
bengel's Avatar
Also how did you get it to run so fast in the 1/4 mile.
ichon Posts: 68
User Gallery
Outstanding run. The lowest et in my stock SRT6 is 12.98 at 113 mph (Capitol Raceway, Crofton, MD) but that took a few (8) runs. The auto-stick can be confusing b/c you want to mash the clutch before the shift. It took a few to get used to banging gears w/o patting the foot. LOL. Anything under 13.50 in a stock machine is hauling ***. Good Job.
Especially the mph that stock car is flying.
Old Aug 11, 2006 | 12:51 PM
my65cuda's Avatar
I'll be curious where 120 rwhp is going to come from.
Old Aug 11, 2006 | 01:24 PM
dynamicS's Avatar
nitrous should get you there, but you'll probably need some expensive gas too. maybe alcohol injection might keep temps down decreasing detonation, are you chipped? what's the timing at?
Old Aug 12, 2006 | 10:04 PM
ichon's Avatar
Its a lot easier in "auto-stick" than in standard. I made a few practice shifts prior to initiating the dyno.
Old Aug 12, 2006 | 10:06 PM
ichon's Avatar
I will let you know when its done but think "air flow" LOL.
Old Aug 12, 2006 | 10:08 PM
ichon's Avatar
ichon Posts: 68
User Gallery
Lots a practice runs and new tires.
Old Aug 14, 2006 | 12:07 PM
SRT6_Roadster's Avatar
Pulley Kit
ECU
SL55 y-pipe
Green Filters
Camshafts
Removal of primary cats
'Upgraded' wires and plugs
The above should put you in the 370-380 rwhp range.
Old Aug 14, 2006 | 12:31 PM
my65cuda's Avatar
What's the SL55 Y-pipe? Anybody have proof that it ads any power? Speaking with Klennman they don't think new filters have any effect on power from their testing.
Old Aug 14, 2006 | 04:37 PM
Not sure if new filters add any power or not. I have seen applications where they do not.
EvoSport has some dyno's showing the SL55 y-pipe adding a couple of ponies. It is not a huge gain but it is something.
The Y-Pipe is the y-shaped pipe that connects the two air boxes to the TB. If you look at the stock version it is very small and restricted. The SL55 has a larger y-pipe that run ~$75 from an MB dealer. It is not a direct bolt on as the tubes are larger but an adapter is easy to make from either silicone couplers or your stock y-pipe.
Old Aug 14, 2006 | 04:42 PM
dynamicS's Avatar
what's the part number on the SL55 y pipe?
Old Aug 14, 2006 | 04:53 PM
dynamicS's Avatar
found a picture on benzworld, it sure is a lot bigger than stock...
the cast alloy is off the SLK32 another option too.
Old Aug 15, 2006 | 06:09 PM
Have not seen the cast piece before. Do you have any information on it?
Old Aug 15, 2006 | 09:25 PM
dynamicS's Avatar
The cast piece is off the SLK32 AMG I believe, cast Y pipe MB part # A 112 090 00 31 - $41.
I think it's the same part on the SRT6 supercharger...?
Old Aug 16, 2006 | 07:04 PM
Have not seen the cast piece on an SLK32 and I have seen several of them in person.
Old Aug 16, 2006 | 07:06 PM
dynamicS's Avatar
Well I'm stumped then. I found it on some guys website dedicated to his SLK32, maybe its a European part?
Old Aug 17, 2006 | 12:19 PM
feets's Avatar
The SLK32 uses the same part as our cars. I believe the SL55 uses a rubber piece as well. I can look in the shop a little later to see if we have one open.
A cast aluminum piece would probably be aftermarket.
Old Aug 17, 2006 | 01:50 PM
dynamicS's Avatar
I don't think its aftermarket cause it has a MB part number.
gblack32
Sep 7, 2016 08:27 PM
Jerrysrt6
Jul 24, 2015 09:15 PM
waldig
Jul 20, 2015 08:10 AM
Zoodust
Jul 16, 2015 06:17 PM
Rusty475
Jul 13, 2015 10:03 AM
